9 hours ago, Kinkstaah said:
Given what I have just done to mine....don't go over 400KW with it...... damage report incoming. :P
I assume you are talking about the manifold.
Love the Turbo Killer avatar btw
I always thought along the lines of 300-330 rear wheel Kw on an RB25 with standard rods and pistons , it's why I wonder if a TS IW 7670 is a bit too much turbo .
I don't have any volumetric efficiency figures for RB25s , they do seem to rev ok but factory manifolds were obviously intended for lower outputs with a turbo that was super restrictive on the hot side . Been a long time since I drove a standard turbo 25 but it was mediocre boost from around 2500 revs and all hisses whooshes etc .
This is why the HKS GTRS (GT2871R 0.64 AR T3) felt better or less restrictive anyway . The 30R was better again but introduced a "classic" bigger turbo feel and needed tuning (timing) strategies in the low rev part throttle ranges to make it feel good on the street again . I'm long past the stage where boost at part throttle and soft pedal revs is worth it because conventional turbos that do that compromise everything else . Doesn't mean modern twin scroll systems cant help here but the whole turbine speed exhaust gas pressure/velocity thing is the hardest part to get right - and everyones "right" differs .
Geoff thanks heaps for the pics of the 7163 and 7064 on the RBs , gives us some packaging ideas . I'll talk to Scott at Insight again because he's tuned most of the EFR range and reckons 7064s are good . You say these have EMAP advantages over TS 7163s , important to me because in theory I could run more advanced timing in most places .
Thanks all cheers A .
Geoff at this stage I think the 0.92 TS 7064 is the best bet for me . I noted what you said about your Ecoboost 2.3L 7670 and where it comes into power .
I also like the idea of an around 3000 rev boost threshold and the slightly larger 0.92 AR turbine housing , surely this combination has to have it all over a single scroll 0.82 AR IW GT3076R . I'm trying not to have the big or small turbo feel and top end revs and power numbers aren't so important to me . 400-450 wheel Hp is fine but a broad spread of power and good part throttle running is essential .
Lastly that turbine housing coating you do , how much of a real world difference does it make keeping the radiated heat in check .
Be in touch cheers A .
In my experience, I would look no further than a 7670 1.05 T4. On my 2.3L Evo, the thing was insane. 30 psi by 3750rpm, at 4000rpm it was making 250kw and 530nm of torque. Then went on to 410kw. But on 98 on 20psi, it was also perfect. Made 285kw, and ridiculously punchy.
There is no such thing as "too much turbo" with the 7670 when it is as responsive as that. I'd expect similar boost threshold on an RB25. I've sort of described it to people as GTX35 power for GTX2867 response.
Here is my dynosheet with EFR 7064 T4 .92 internal wastegate.
RB26 is stock, fully balanced. 6Boost manifold, 3" exhaust. Bosch Motorsport 970 injectors. Stock ITB setup.
You can see it dies out on top. So I will probably go for the 7670 T4 for 2017 season.
This is on 98 RON fuel. Measured on the hub.
I believe the 0.80 a/r vs 0.92 a/r is a bigger argument than 7163 vs 7064 rotor pair.  It takes much more wg spring to keep the 7163 spinning up to max speed than the 7064 - due in large part to the a/r differences
Any chance it would fit under the stock heat shield & line up with standard intercooler piping?
On 11/11/2016 at 4:43 PM, discopotato03 said:
Geoff at this stage I think the 0.92 TS 7064 is the best bet for me . I also like the idea of an around 3000 rev boost threshold and the slightly larger 0.92 AR turbine housing , surely this combination has to have it all over a single scroll 0.82 AR IW GT3076R . I'm trying not to have the big or small turbo feel and top end revs and power numbers aren't so important to me . 400-450 wheel Hp is fine but a broad spread of power and good part throttle running is essential . Lastly that turbine housing coating you do , how much of a real world difference does it make keeping the radiated heat in check .
Adrian, I agree this combination could work well.  just make certain to get the IWG actuator and spring rate dialed for your needs.  This is a critical part of optimizing performance from twinscroll IWG efr turbos
Sorry I do not know yet
4 hours ago, Deano 1 said:
wheres the best place to order one of these bad boys, should i be looking in the states or australia?
Full-Race carries almost every variation of EFR turbo in stock - and our annual black friday sale starts next week.  If youre looking to pick up a turbo, this is a good opportunity
14 hours ago, SSM said:
Here is my dynosheet with EFR 7064 T4 .92 internal wastegate. RB26 is stock, fully balanced. 6Boost manifold, 3" exhaust. Bosch Motorsport 970 injectors. Stock ITB setup.
The 7064 is too small for RB26.  I believe there is much more performance to be had once optimized.  However your dyno chart shows only 200hp by 3500rpm - so there is likely an issue with the IWG actuator being too soft and getting blown open
20 hours ago, Tom Tucker said:
In my experience, I would look no further than a 7670 1.05 T4. On my 2.3L Evo, the thing was insane. 30 psi by 3750rpm, at 4000rpm it was making 250kw and 530nm of torque. Then went on to 410kw. But on 98 on 20psi, it was also perfect. Made 285kw, and ridiculously punchy. There is no such thing as "too much turbo" with the 7670 when it is as responsive as that. I'd expect similar boost threshold on an RB25. I've sort of described it to people as GTX35 power for GTX2867 response.
7670 1.05 a/r is our #1 most popular efr turbo for a reason!
Edited by Full-Race Geoff
Going by the photos, it looks like it fits nicer than my GTX3582 (the borg warner is smaller, in those photos), so it can be used with engine bay piping without any major concern I'd wager, as my GTX does/did.
Kinkstah, the turbos i posted photos of are much smaller in wheel size and airflow rate than your GTX3582 (they're much earlier spooling turbos).  Keep in mind your GTX3582 has an "82mm compressor" - this is a very big singlescroll turbo considering your setup.  It is comparable to an EFR8374 with "83mm compressor".  I can assure you that if you tried to cram a large efr 8374 in this area you would quickly run out of room also!
@Full-Race Geoff Geoff, you've made a few comments about the high back pressures in the 7163 TS 0.8. Is there any future plans for a larger rear housing ? What are your thoughts on modifying the manifold to external gate and using some threaded rod to hold the IWG shut (instead of welding).
Is there much of a penalty going from the twin to single scroll ? I noticed the twin scroll not listed on the webpage anymore ?
Cheers !
The 7163 is an excellent turbo in twinscroll and singlescroll configuration.  I have a few rally race customers that removed their $10k TR30R and switched to 7163 vband ewg (off the shelf) and gained performance.   the 0.80 a/r twinscroll is optimal for very early spool on the 7163 but will hit an emap wall before the 0.85 singlescroll..
There is a possibility of larger A/R twinscroll housing in the future, but borgwarner moves slowly so this is wayy out.  Modifying the manifold to external gate offers zero benefit, backpressure is dictated by the volute not the wg config.  thanks for the heads up that our new website is missing the twinscroll 7163.  we just launched this site and finding small errors all the time
  • Like 1
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
