12 minutes ago, SimonR32 said:
I have questions that if answered may cost me a fair bit of money so please don't respond.
Do you have a photo of the turbo on the T88 kit, I also have one but scared of the clearance of the massive EFR?
Do you have a graph from the hubber, although a 9180 on a 2.8L it might give me an indication of similar of a 9174 on a 2.6L?
How can a camera even record at 240p? haha
I posted a graph a page or so ago :) It's kw at all 4 and not all in, he was aiming for 600kw and stopped there for pity for the transmission haha.
Edited by Lithium
Because everyone likes photo's.. this is not my car so details are only 95% accurate.
Nitto 3.2 EFR 8374 1.05 twin EXT gates
~23.5psi back to 21-22 up top on E85
480rwkw (possibly slightly over spinning the turbo but not sure. 6 Speed getrag
  • Like 5
lot of power for 'only' 23 psi
curious to know whats done to head
It's a 3.2. It's going to swallow air alot easier then a 2.6.
Thats 2 3.2/8374's that have returned pretty much the same power for the pressure used.
Got a speed sensor yet?
Turns out Full-Race wanted to share this clip so made an effort and got a higher res version of the 9180 R32 GT-R at Hampton downs, in case people wanted to see it with more than 48 pixels:
2.6ltr or 3ltr?
3.2 should just bring it on earlier.  2.6L should still make same peak power if revved hard enough
My gate pressure was approx 21 psi and mine mad 390kw on JEMs dyno and then 500kw on 31 psi on a freak run (call it 490kw) so it is  roughly 9kw per psi which is why 480rwkw on 23 Surprised me.
Rw to awkw could make  diff.
And no on speed sensor. Been flogging it on 30 psi as it is :)
I didn't know Mr Brooking went single turb......finally got rid of those shite boxe Tomei twins!
.....looks scary, needs more 4wd controller.
Edited by Sub Boy32
  • Like 1
Pay more attention in my group on Facebook sir.  There was a discussion about the potential change, then on a suitable EFR, then dyno results etc :)
  • Like 1
And no on speed sensor. Been flogging it on 30 psi as it is [emoji4]
The 3.2 might be running high compression which would help it make decent power even at relatively mild boost.
My makes over 525kW at 26psi - RB2530 10:1 not running an EFR though.
Fair enough
Finally got my hands on a 34 GTR tail shaft.
Going to do the 34 GETRAG conversion while retaining r33 GTR diff gears for even shorter gear ratios.
8374 with even shorter ratios = super responsive street car :D
Come to our next track day in September, real men race on the track not the street :)
  • Like 1
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
