7 minutes ago, Nismo 3.2ish said:
I reckon,  go one down for the street or find a slope to get it going ?
You need to go in a "normal spec" GTR after your own sometime, and realise that maybe what you're trying to build isn't a GTR at all :P
  • Like 2
From what I have heard, your right. I only drove 1 car from the getgo, built motor and a T78 , why wouldn't I try to change it , it was crap on the street , no, it was the worst car I have ever owned , not the cars fault, it was mine for not knowing anything about modified cars, silly me , lol.
The other  GTRs I have been in were great but worked over so I had never been in a stock car, but I have not seen any "stock" GTRs on this site or anyother sites that have not changed something on their car to make it better.
Now I have a car "I" like to drive ,  lots of help from SAU blokes  :)
Not sure what to call it after your statement, maybe GTRRRRRRRRRSTEFR
I ended up going up a size to the 8374, and while I will be happy with it I also think I would have been quite happy with a 7670 aswell. Maybe even more so for day to day driving.
i need to pull my finger out and fix the niggly issues and get it tuned on full boost and E85 though
  • Like 1
1 hour ago, Piggaz said:
Any ETA for the tune pete?
A high comp 2.8 doesn't need a 7670. Needed a 8374/1.05!
THAT!^^^ You haven't even driven the thing properly lol so dont comment till its sorted ?
9 hours ago, Lithium said:
Cheers for the updates - that is actually even laggier than I expected, but of the ilk.  Glad you are at least not having issues building higher boost levels.... is the higher boost/E85 tune still being done today?
641+whp on 91 on a Mustang dyno isn't kidding around, that will be very interesting with E85 in it :O
The car was a dog under 4k rpms before and that hasn't changed now. However, it feels like a better drive overall, especially shifting gears. It doesnt seem like the boost really ever drops which feels fan-f**king-tastic. I don't have the dyno for e85 on me (will post tomorrow) but it made 758 on e85 tuned semi-conservatively, which after driving I am pretty happy with. Will have more updates to follow tomorrow.
Sounds not too bad all things considered!  So was there any reason why it's tuned conservatively or not pushed as hard as it initially sounded like you would?  They should have HEAPS in reserve.
Keen to see the dyno plots and the further updates you mentioned :)
No tune for a few more weeks still.
Got 3.5" exhaust made up and moved the pod filter off of the turbo over to the old washer bottle spot so it can suck in air from the guard at least, so nothing really left to do apart form track down a very small oil leak (turbo drain i think) and a idle noise that started up (possibly new exhaust?)
Went for a drive over nebo. Car wasnt exactly coming from a good palce for that but dayum its not half bad now... and will only get better with E85.
Certainly don't think the 7670 would have been better enough to justify the 60+kw drop on the top end.
  • Like 2
Hey guys I'm a bit late to the party!
anyone running a 9174 on their 26 or 30 yet? The evo boys seem to be making good numbers out of them but haven't heard much from the GTR community
and what are people's thoughts on cast vs alloy housings?
  • Like 1
Will be looking forward to see how it goes!
what size housing did you get and what power/ goals are you aiming for?
I only recently found out that the alloy housing is an option, cost to me isn't a factor I guess if reliability isn't a sacfrifice then I'll opt for the alloy one. (I will be water cooling regardless)
Have you you tried inducing overlap in the cams a bit? May car (granted on 8374 .92 IWG) spooled 5-600 rpms sooner and made 30 more ft-lbs of tq when I rolled the cams in. HUGE difference on boost threshold and mid range. I did lose 10 hp on top but the car overall is def faster and easier to drive
the 9174's have been very popular lately, for 2 reasons:
-borgwarner has the most bizarre production methodology ever, and they are spititng out 9174s only  (not 8374, not 9180)
-the 9174 has an internal pricing error causing it to be the least expensive of B2 frame EFRs.
we get shipments of 9174 with iron and alloy bearing housing.  The main factor for consideration if you will use alloy  is that watercooling is mandatory.  the iron turbos are not nearly as picky.  however the alloy turbos are crazy lightweight, its a 7lb difference
Edited by Full-Race Geoff
  • Like 1
  • Thanks 1
I was amazed how light the alloy ones are.
Why is the 9174 so cheap? That part reason why I got it.
I still haven't got a rear housing yet . Got stuffed around by Sparesbox.
Was waiting til gcg got them in stock as shipping from overseas was a killer.
Will be using 1.05. don't have any power goals, whatever it makes on 26 -30 psi on e85.
I am not sure and I don't personally know how to check. I would have to ask the tuner. I also think that would require a retune as well. The shop is remote from me so it's not easy to make changes unless I go elsewhere.
After speaking with the tuner further, I believe that 750 was all he could get out of the setup. If they can do more, I don't know what other changes could be made to extract more power.
Interesting - I would have expected more than that!    Still, must be pretty solid even with that?
On 03/09/2017 at 3:42 AM, minesskyline said:
@Full-Race Geoff Do you know why the wastegates would allow small amounts of oil to be blown out from them? I have the turbosmart wastegates from your site.
That doesn't sound great :/
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
