R32 4 door to 2 Door conversion?
Experts,
This thread is about a project overseas, not in AUSTRALIA.
I was wondering whether it is possible to convert R32 4 door sedan gts4 to a R32 GTR? (NOT in AUSTRALIA)
If so, how complex will the chassis mods be?
The reason for thinking of this project is, it is not legal in Bangladesh to import any cars over 5 years of age. Hence a R32 can no longer be imported. Only solution is HALF CUT imports. Therefore, I was wondering if we can use the parts from the HALF CUT for a GTR conversion? Moreover, wanted to know whether Sedan to Coupe conversion is also possible? Or does it have to stay 4 door?
Thanks in Advance!
https://www.sau.com.au/forums/topic/467737-r32-4-door-to-2-door-conversion/
The main problem I see is that the coupe door is wider and therefore the pillar needs to be relocated. Secondly unless the job is done to a very high standard you could end up with a death trap in case of an accident. And I have no idea what the regulatory regime is like in Bangladesh. Four door R32s can look cool.
1 hour ago, MarvinsR33 said:
The dumbest thread I've read so far.
Dude, wtf just buy a 2 door GTR32.
This is S(AU) for a reason
You're an idiot
Op
I doubt it is financially viable
But yes it is possible given enough skill and money.
No reason you couldn't just drop an rb26 in the bay and upgrade the brakes etc and make yourself a 4 door GTR
  • Like 3
Mate, that's quite uncalled for, if you actually spend 30 seconds and read the post, he can't import a 32 GTR as the countries laws don't allow it and he obviously has access to a 4 door 32 that's all ready in the country. Unless you have something constructive to say, don't say anything at all.
OP
It would be possible to do, but the engineering required to do it and also the money would make it probably not worth while, it would need to be dead straight and chances are it would never drive and handle correctly.
I think @zebra is onto the right idea, get yourself a half cut and convert the running gear and front end of your 4 door over to a GTR, you will be able to pick up the rest of the various goodies along the way to bring the interior and rear up to spec. i like the idea of a 4 door 32 GTR
Edited by Coullsy
Fixing spelling errors
  • Like 3
@Coullsy, @KiwiRS4T, @zebra Thanks heeps. I was thinking along a 4 door 'GTR' conversion all this while. Just wanted to get more info from you guys!
@MarvinsR33 dude I have a 94 R32 GTR in AUS. Like I mentioned in the thread, it is not possible to import these into Bangladesh.
This comprehensive R34 sedan to GT-R conversion will give you an idea of the effort required, it's pretty insane:
http://www.carscoops.com/2016/09/nissan-skyline-r34-gt-r-gets-4-door.html
The pillar is just one problem. AFAIK:
  • Front window rake and glass is different
  • Rear window rake and glass is different
  • Floor pan is different
  • Door cards are different (obviously)
  • Rear interior, seats and parcel shelf are different
  • The boot, in fact the whole rear end (including tail lights) is different (see photos on above page)
  • Exhaust system is different
etc. etc.
It's totally not worth it.
However, what IS worth it is a sedan with GT-R running gear. A much cheaper proposition too - do it!
Not sure if it's option or just stupid.. but put the 4door neck together but weld the doors and make it flush to make the appearance of a 2 door?
I know it happens with other cars in Indonesia. Not sure if it'll look funny though.
Just an idea :)
If You're happy with the 4 doors then it'll only be possible with an accompanying SAU build thread. :)
Hey@marvinsR33 keep that crap out of this site please mate. Not interested in reading that drivel.
@V28VX37thanks heeps mate!
I will definitely go ahead with a 4-door build. When I do, will definitely start a thread to seek help from you lot. Unfortunately won't be very soon as I just moved to AUS.
Thanks everyone for your knowledge.
  • Like 1
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
