4 hours ago, Adzmax said:
I picked up an R200 with a 4.4 LSD on the weekend, I'll strip this down and rebuild it along with the rest of the rear end in the coming weeks.
7 Days for a update bruh, whats happening :P
In all seriousness, take your time, build is looking awesome :D
7 hours ago, jmknights93 said:
Such an awesome thread. Loving these updates :)
Thanks mate!
Some goodies we purchased in Japan at Nostelgic 2 Day arrived today (no pun intended), a set of S.E.V Marchal headlights.
  • Like 2
It's been a pretty crazy few weeks so not a lot happening on the car front, hoping to reassemble and pain the GTR grill this weekend though. I can't for the life of me find the paint sample we made up so I had to get a mate to send me down his colour chips for matching, no paint codes available for this stuff unfortunately.
I was going though some boxes from my trip to Japan in Feb this year and found these goodies. Some door handles, a GTR style gear know, NOS badges, water heater seal and stainless trim for the centre console.
Also a whole bunch of stickers for the car, it's the little details that make the difference! :)
  • Like 2
So a pretty major development this week, Lachlan Fowler at Les Collins Racing had a fully built 3.3ltr L series short block for sale which I've purchased. He's decided to go down the full billet crank race spec path meaning the built bottom end is no longer needed. I'll supply my own P90 head to the builder to be ported, polished and rebuilt. The motor should be good for 350hp and 280ft'lbs of torque with the right head, cam and induction.
Short motor specs are:
  • L28 3.3ltr short engine.
  • 89mm bore x 89mm stoke = 3322cc
  • Engineered by Les Collins
  • F54 block. Acid dipped, 1/2 grout fill, sonic tested & offset bored to 89mm & finial diamond honed to exact clearance.
  • Deck milled parallel to crank tunnel centreline.
  • Clearanced crankcase, de-burred & painted in Gyptal.
  • New gallery plugs. Blanked oil pressure relief port.
  • Standard sump & pickup (to be replaced with Kameari pickup)
  • Modified 89mm stroke crankshaft, oil gallery plugs tapped & plugged.
  • Custom CNC billet steel 8.8kg flywheel to suit crank (no clutch assy).
  • 137mm I-beam connecting rods with ARP2000 rod bolts.
  • Custom SPS 89mm forged pistons – designed to work with a P90 head.
  • New timing chain guides & new Kameari HD timing chain.
  • New OEM front timing cover (de-burred, polished & water-jet blasted) fitted with replated bolts.
  • New Water pump.
At this stage I'm looking towards injection as the 44 Mikuni carbs I have just wont be big enough and would limit the motor to around 280hp. The other option is 47mm OER carbs but Jenvey make a 47mm heritage DCOE twin body with the injectors hidden in the body. Heritage look with modern features. I'll need to look at a fuel tank conversion using EFI hardware's EFI conversion kit and consider an ECU, perhaps Motec M800 or a Haltec equivalent.
Not sure who will complete the head work and engine but at this stage I'm looking at either Peter McDonnell or Les Collins Racing, both are true professionals and will do a great job.
Here are some shots of the motor before it will be torn down:
  • Like 2
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
