39 minutes ago, mlr said:
Looks a million bucks, noice
Having some buyer's remorse 😅
Could have went towards a depreciating M2/3/4 lol.
  • Haha 1
Fark the 3 pointed swastika pos
Or sell up now and buy a 3 pointed swastika and regret?????
The old Datsun is gold dust, any muppet with a job can own a BMW
My 2 cents is to stop treating the old girl like a dirty bitch
Not saying to not run her hard, just saying to not treat her like a dirty slart
  • Like 1
  • Haha 1
For some reason a bunch of n54 bmw videos have come up in my feed so I watched a few and f**k they have some issues.
gotta spend the value of the car every year just to keep the oil inside the engine and the engine check light off and then all the body modules start throwing trouble codes up
Don't forget WALNUT BLASTING + VANOS Issues lol
Probs still gonna buy one at some point =\
  • Thanks 1
Just saw engine nudes,
that f**king sucks dude. What size restrictors did you put in when building the engine?
Also who did the respray and rough cost? Looking to get S15 done
@niZmO_Man lol not the look I'm going for, that's too IG try hard, get likes and attract fk bois look :D
@iruvyouskyrine Good eh? lol... the bottom end I believe had 1.2 restrictors in it, however none were blocked off (this was recommended by the shop that built my bottom end). Respray wise, it ended up a bit over $15k with the guard work (F&R), glass removal, rust work, hail work, front windscreen replacement, fitting the skirts/pods, shaving off the GT-R logo on the wing, lengthening the front lip (as the Car Mate one is too short, no joke!). I did get carried away, initially it was going to be a basic respray, then nek minnit.....
  • Haha 2
Don't worry bro, in this market, with a fresh coat of paint and some rotas it's a 50k car....
  • Haha 2
How I managed to crack an AWD block in a RWD car with only a measly 407kW makes proves the NEO AWD blocks aren't unicorns 🙁
  • Confused 2
  • Sad 1
Someone tagged me in this, sad reacts only 😅
When it worked, then it didn't, then I all thought was it would have needed a simple fix, then I find the head is cactus then somehow the car gets a makeover 😅.
Then a few weeks later I find the block is cracked.
119217053_2773272086242183_6513774598418894058_n.thumb.jpg.d06e0eea3a4e5fd98fd4b47ef97fb617.jpg
  • Sad 3
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
