2 hours ago, admS15 said:
Or she's worried you'll start modifying the M3 and it'll end up just like the skyline anyway.
100% this, it would just end up being a new black hole for the funds to be shovelled into lol.
  • Haha 2
If course he would modify it
It would be so easy to get some good power out of it with "dis and dat"
I have the same disease, I cannot leave things alone, even things that you don't really need to do, or even should do, because, "why not", like basically everyone else on this forum to varying degrees
Or, he would spend the next 10 years fixing all the typical Euro issues as Uncle Duncan has stated
  • Haha 1
So for the longest time, I used the Haltech canbus keypad to turn on or off the AC compressor because for some reason the HVAC controls kept turning the compressor off as soon as it went on.
Turns out the stupid AC Thermistor BS had died like all the other Nissan shit boxes in the 90s shit box era. Been trying to find a suitable replacement but it's discontinued and the modern ones from other Nissans are 6x pin.
Fear not, after mindless SAU research it turns out you can crack open the thermistor circuit and replace the fked cap, that I did (take note on that white piece of mdf).
AC now working as expected and the HVAC controls work perfectly.
Now the fun part, went to park up the shit box just then and now there's a pile of coolant. Seems like it's coming from somewhere between the motor and box, fk this piece of shit. Also as I was looking for the leak, that white piece of MDF I used as a makeshift shelf, it snagged on my shirt and landed on the bumper, taking a chuck of paint off.
Lol.
So TL;DR, AC fixed, new coolant leak and chipped paint off the bumper.
  • Like 4
Nissan shit box things.
Can't see any leaks from the heater hoses, anything behind the head, or engine bay.
I suspect maybe it's a welch plug on the block near the flywheel area.
Fk this car.
  • Sad 4
9 hours ago, niZmO_Man said:
perhaps there was a pool of coolant in the chassis or subframe and it finally escaped??
I think there a tiny bit left over in the expansion tank and lines which have been removed/spilled some down in between things.
Just funny to see the green through an empty bay.
  • 3 weeks later...
That makes it 2x broken cars at home.
Both kind of work, one leaks coolant when warm one skips 1,3,5,7 gears when warm.
Lol.
  • Haha 2
  • Sad 3
Is it still under warranty? Ducken VAG crapbox.
My wife's ford focus junk dct did something similar a few years back, was borked TCM module.
Recently it intermittently didn't want to release clutch and would just be in neutral for a few seconds. Clutch fork was binding randomly from clutch dust build up. Some brake cleaner, a spline tool and working the clutch fork back and forth manually sorted it.
Unkind reminder that VW SUV significantly less expensive and way more reliable than BMW sporty car. let alone a modified BMW sporty car.
  • Like 2
Can we get this pinned some where
  • Like 2
  • Haha 1
1 hour ago, admS15 said:
Hopefully they do a goodwill repair on it. Fingers crossed for you 🤞
I hope so, hope being loyal to the stealership has some positive(s).
Shitbox has been exclusively serviced by VW, even though I could do it myself for heaps less.
In good news for Euro car buyers, manufacturer warranty is not relevant. Under Australian Consumer Law, what you buy has to be free from major defects for a reasonable period. And if its not you get to choose between replace, refund or repair. VW were specifically done in 2018 for not complying.
https://www.accc.gov.au/by-industry/cars-and-vehicles
So, just say it is not reasonable to have this failure so soon, and ask for your money back, and buy a nissan.
Of course, there is a possibility that they will disagree and you spend the next couple of years in court trying to prove it
  • Like 2
Thanks @Duncan let's see how I go next week.
For good measure, just happened again. Daily occurrence 🥲
Will get it fixed and wait till the Minister of War & Finance is back to work so we have more cash flow instead of torching our savings before we buy a new shit box (won't be a Nissan, soz).
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
