16 hours ago, Robs0re_34 said:
Have you got any r34 wheel arch covers left? And pollen filter and under cover lol
yes i have heaps of filters, still have engine under covers but no wheel arch covers. Send PM if you want to buy it
Updated:
R32:
R32 GTS-T/GT-R Rear Windscreen (2 available) - $350
R32 Coupe Door Trims Pair (Suede has been ripped out clean, can use as is or stick on yourself) - $200
R32 GT-R Interior Carpet, Good condition - $250
R32 GTS-T Interior Carpet, Good Condition - $150
R32 GT-R A-Pillar Trims Pair, very good condition - $250
R32 GT-R A-Pillar Trims Pair, 1 side has 3 or 4 broken clips - $150
R33:
R33 Engine Splash Tray (4 available) - $50
R33 GTS-T Full Boot Trim (2 available) - $200
R33 GTS-T/GT-R Boot Slam/Scuff Panel (2 available) - $40
R33 GTS-T M Spec Side Skirts in QM1 Polar White, good condition - $200
R33 GTS/T Midnight Purple Driver Side Guard - $100
R33 GTS-T S2 Grille M spec - needs mesh (Supercheap Auto has meshes, cut to fit) - $80
R33 GTS/T Series 1 Passenger Side Headlight, good condition - $150
R33 GTS/T Series 2 Front Fog Lights/Indicators - $300
R34:
R34 Cabin Filters - To suit all R34 Models, BRAND NEW aftermarket - $35
R34 NISMO GT-T Automatic Cluster - $450 (GT-T Models only, may work with HICAS NA's but can't guarantee)
R34 Under engine splash Tray (3 available) - $50
R34 Sedan Side Skirt (LEFT ONLY) - $120
R34 OEM Fog Lights Pair - $200
R34 GT-R V-Spec Differential - $900
C34 Stagea Bonnet, Series 2 in black - $250
One Size Fits Most:
New Gates Racing Timing Kit to suit all RB - 4 available - $200 ea.
RB26 Rocker Covers (no coilpack cover or timing cover, powedercoated wrinkle red) - $450 pair
RB25 Raceworks Fuel Rail, new, fitted and removed, never used - $120
RB25 ARP Head Studs 202-4301, NEW SEALED - $250
RB26 ARP Head Studs 202-4207, NEW UNSEALED BOX - $400
Mongoose M20S Alarm System (8 available) - $120
Genuine Nissan PCV Valve Grommet, suits all RB, VQ, SR, CA, VR etc. - $10
Genuine Nissan RB25DET M/T Speedo Gear Cog 32743-30P20 - $20
Genuine Nissan RB25DET M/T Gearbox Yoke Seat 32870-V5003 - $40
Genuine Nissan RB25DET R33 M/T Gearbox Yoke Bush (big type) 32861-01G00 - $20
Genuine Nissan RB25 R33 R34 Gearbox Yoke Bush (small type) 32861-H7301 -  $10
Genuine Nissan R33 R34 M/T Speedo Sensor 25010-21U00 - $200
Genuine Nissan Oil Pump Gasket RB Engines 15066-71L00 - $20
Pro-Torque Rear Main Seal, suits all RB - $35
Permaseal MLSR RB25 Head Gasket    S4413MLSR, new sealed - $250
On 04/04/2017 at 11:40 AM, Livinlahtimmah said:
I will take a 34 under engine cover please
send me a PM :)
On 05/04/2017 at 0:50 AM, ozzydee said:
Have you got the under steering wheel dash ? R34
Yes I do, PM me
Interested in one of these, can pick up.
I'm also chasing the steering column plastics (top and bottom) for a 33.
send me a PM
On 27/04/2017 at 1:43 PM, frostyboy said:
Could you please post a picture of the splash tray to suite r33 gtr
And also looking for under gtr wing plastic trim
sorry dont have to suit GTR
On 28/04/2017 at 3:59 PM, Bobtek said:
Do you have the R32 GTR rear parcel shelf? And if possible to post up some pics of the R32 GTR door card trims? Thanks
parcel shelf sold. PM me for door card and trims
On 14/03/2017 at 10:08 PM, viper2002 said:
Interested in R34 the under splash tray, do you have the one for the left wheel arch?
found a pair of these $100
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
