Pretty sure CEF33Y is running a TD05-18G from memory.
Here is a bit more info and another pic because your image doesn't work on mobile lith.
It says it's in a nissan housing but doesn't mention what A/R. Either way its pretty shit and the exact opposite of what i am looking for haha. I agree that a 7163 would crush it and i'm hoping a 6758 would be miles ahead in repsonse and still make roughly the same power.
Price wise the best i have found for a 6758 here in Australia is;
$1506 for a iron bearing supercore
$630 AUD for a G type (T4 TS .80 A/R) turbine housing
$16 for turbine locking tabs
$78 for wastegate brcaket kit and i already have an EFR compatible single port turbosmart wastegate
So roughly $2200 compared to the $2800 that cartel online has them listed for (which is the cheapest in AUS) and the $3000 that GCG has them for.
Almost ready to pull the trigger on buying this EFR setup!
  • Like 1
Nah, I'm running a Hypergear OP6 highflow.
Stock manifolds, unopened motor, just supporting mods on 98. Cheap setup, and i'm pretty happy with it (read- used to the lag)
Super keen to see what results you get though.
  • Like 1
Ah yeah, 18Gs are one of my less favourite units funnily enough - not least because they are heading in the direction of 20Gs for lag and 16Gs for power... hence I figure you go either 16G or 20G, there is no worthwhile in between despite everyone going for the 18G for some reason. <edit: I see Cef33y isn't, though the same still applies but it's more understandable that it's got so little at 4000>
Cool man, would love to see how that setup will go on a 20!!!  There is a disclaimer I always give for EFRs, don't jump to any conclusions of how it is performing until you actually drive it :)
Edited by Lithium
Yeah my bad i was thinking of CRSKmD! Yeah im sure it would be fun but the lag would be horrible for me (coming from a RB25/30 neo with a SS2 .82 rear). I fking love RB20's though and a 260-300kw RB20 is not by any means a slow thing. Sure its no absolute powerhouse but that is heaps of power to go and have fun at a track day/drift day. So i am obviously trying to cook up the best streetable RB20 possible.
And drive it i will! This is not going to be a car that lives in the shed, will be driving it daily as much as i can haha. I think i found your mate with the 7163 on the 3sGTE on youtube as well.
FWIW i have purchased a Garage7 IPC and will be using that in this build also. Seems like a very cool but of gear but will be interesting to see how it actually works in the real world.
Yeah, my cars have always been laggy, so don't know what I'm missing, haha
At 240rwkw, its plenty for what I do (drifting). Bonus is I don't use as many tires as other peeps.
They're saying that the turbo is creeping like hell and they managed to control it via their IPC (and a very soft spring I suppose) instead of porting the shit out of the wastegate.
So yes I think there is room for improvement, beginning by the wastegate porting.
8 hours ago, driftnick13 said:
It's on a hub dyno, not sure if that makes a difference.
Nope, I've had a 50trim T3/T04E on the stock manifold a hub dyno with a stock RB20 and it was similar to the GTX on that plot... unless a VERY fast sweep was selected it seems rather laggy for what it is.
Turbo purchased and should be here in next 2 weeks. Manifold getting made at the moment :) really wanted to make an exact copy of the Gibson one but there was a few factors stopping it and I ended up going a different route. Manifold is getting made with a 8374 so if i ever go RB26 it will fit perfectly no dramas. Baby little 6758 should fit easily haha.
Cooler piping will be done when turbo turns up.
received_10212408355514650.jpegreceived_10212414287582948.jpegreceived_10212414286222914.jpeg
  • Like 3
A hole in the bonnet should do it. It'll be easier after the first outing, just cut out the burnt area of paint!
Should be a fun car to drive, there's something about revving the crap out of an rb20 that feels good.
I know right! I honestly really do love them. Cant wait to spin this thing as hard as I can :)
Should sound great with that manifold, post some videos up when it's done.
Hopefully mate! The sound was a large part of the reason I went with a manifold like this. Will be going 3" straight through with twin 3.5" tips from Diff back
As I said there was a couple of reasons I couldn't go Gibson style, that was originally what I wanted. But after talks with my fabricator and facing some facts I decided on just going a completely custom manifold. Hopefully i can still get it to sound as close as possible to the Gibson item.
After deciding not to go with the Gibson I though I would try the gts-r manifold route. But decided against that in the end too. I have some tasty up close pics of a gts-r manifold though if you want them [emoji14]
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
