Apologies, I know there are probably loads of threads about this. A search brings up a stack of results but nothing that specifically answering my question.
My stock turbo popped on my R33 GTST (I think its series 1.5). There is slight shaft play and the impeller is touching the housing.
Question is, should I recon it and have the ceramic wheel replaced with a metal one or change the turbo?
My end goal is 400-450hp. The plan was to do injectors, MAF etc. before the turbo but i have to change that around now.
If I change the turbo, what are the suggestions for something which will be a straight swop or close to it?
The car is basically stock with just a milteck exhaust.
https://www.sau.com.au/forums/topic/473250-suggested-turbo-on-a-stock-rb25/
I used he atr45 externally gated from hypergear turbo on my 33 on 98 and made 300kw atw. Great bang for buck. I had all supporting mods 750cc injectors haltech etc if you Have more money to play with gtx3076r gen 1 or 2 is also a great responsive turbo.
Another vote for GTX3071 here.
OP mentioned he was thinking about injectors and AFM etc, so this is a turbo that will make the most out of that. GTX3071 may be not THE_BEST_EVER for outright performance on stock RB25, but it is by far the simplest way to get 99% of the performance anyone is going to ever need given what you've said just now.
I have an Rb25neo with an ATR45 and a mate with a GTX 3071 Gen 2 also on an Rb25neo making roughly around the same power.
Cept my ATR45 is laggy as and you really feel the boost kick in. GTX 3071 Gen 2 is linear and happy days.
High mount, twin scroll, twin gates or one massive single gate and a modern turbo.
Keep the exhaust pressure down and the motor will live.
Food for thought, stock motors will happily crank out ~370kW at the wheels for days if you don't abuse them like a wh0re on the track.
  • Like 2
Atr43g3sat with external gate from hypergear looks to be the goods, best response for that power from what ive read and also for the right price
Surprised by all the gtx3071 votes, lots of people talk about using that turbo but ive not really seen too many that do (dyno graphs that is)
Not sure if there are many results on the GTX 3071 Gen 2 on an RB25 but here is one:
Its a built motor though, but it also has alot of restrictions.
For a internally gated setup the flow of the engine system is strongly dependent on the exhaust, so in a common scenario it will be what ever an 3 inches exhaust can flow, and that is usually up to around 400HP wheels. Anything rated to higher power levels is recommended to work with an external gate unless can run a big straight pipe to ground.
Far as power and response, I recommend our latest Ball bearing ATR43SAT series.  ATR45SAT (Note: ATR45 (3582) and ATR45SAT are very different turbos) is capable of making alot more power if externally gated is in mind.
ATR43G3SAT CBB Power 317rwkws P98 fuel internally gated
ATR43G3SAT CBB Boost 317rwkws P98 fuel internally gated
19 hours ago, Die$eL said:
The car is basically stock.
There's a lot of recommendations made that are going to require a $10k minimum spend to make the car capable of running reliably.  They're not bad ideas, just failing to acknowledge the financials.
Until OP is prepared/able to pony up for all the regular associated upgrades - ECU, cooler, proper exhaust, fuel system, clutch, rubber, brakes, suspension I'd say he's best to stick with a small close to stock sized replacement running low boost eg 10psi and keep motoring until the funds are there.
  • Like 1
Well, if you want to be sensible about it, it doesn't make any sense to buy the "wrong" turbo for his end goal now, just so it won't overrun his injectors and AFM.  Piggie's original recommendation (and mine) implied that he would buy the turbo he wanted AND make sure he had the fuel and management also, although I'll admit that we didn't make that real clear.
Needless to say, the whole exercise is probably best reconsidered.  What the OP really needs is a 2nd hand stock R33 turbo to throw back onto the car until he is actually ready to do the needful.
  • Like 1
But it's SAU, when does anyone listen to sensible recommendations?
My pick would be:
  • Top feed conversion
  • External FPR
  • Wallah bro 460
  • Splitfires
  • Nistune with Feature Pack
  • Continental Flex Sensor
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
  • Traction Rods, Rear camber arms, castor rods, HICAS eliminator
  • Intima SR brake pads all round
Call it a day, 300kW street beast.
My pick would be:
  • External FPR
  • Wallah bro 460
  • Splitfires
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
Pretty much just described my car, almost. Can confirm its an awesome setup on E85.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
