Apologies, I know there are probably loads of threads about this. A search brings up a stack of results but nothing that specifically answering my question.
My stock turbo popped on my R33 GTST (I think its series 1.5). There is slight shaft play and the impeller is touching the housing.
Question is, should I recon it and have the ceramic wheel replaced with a metal one or change the turbo?
My end goal is 400-450hp. The plan was to do injectors, MAF etc. before the turbo but i have to change that around now.
If I change the turbo, what are the suggestions for something which will be a straight swop or close to it?
The car is basically stock with just a milteck exhaust.
https://www.sau.com.au/forums/topic/473250-suggested-turbo-on-a-stock-rb25/
I used he atr45 externally gated from hypergear turbo on my 33 on 98 and made 300kw atw. Great bang for buck. I had all supporting mods 750cc injectors haltech etc if you Have more money to play with gtx3076r gen 1 or 2 is also a great responsive turbo.
Another vote for GTX3071 here.
OP mentioned he was thinking about injectors and AFM etc, so this is a turbo that will make the most out of that. GTX3071 may be not THE_BEST_EVER for outright performance on stock RB25, but it is by far the simplest way to get 99% of the performance anyone is going to ever need given what you've said just now.
I have an Rb25neo with an ATR45 and a mate with a GTX 3071 Gen 2 also on an Rb25neo making roughly around the same power.
Cept my ATR45 is laggy as and you really feel the boost kick in. GTX 3071 Gen 2 is linear and happy days.
High mount, twin scroll, twin gates or one massive single gate and a modern turbo.
Keep the exhaust pressure down and the motor will live.
Food for thought, stock motors will happily crank out ~370kW at the wheels for days if you don't abuse them like a wh0re on the track.
  • Like 2
Atr43g3sat with external gate from hypergear looks to be the goods, best response for that power from what ive read and also for the right price
Surprised by all the gtx3071 votes, lots of people talk about using that turbo but ive not really seen too many that do (dyno graphs that is)
Not sure if there are many results on the GTX 3071 Gen 2 on an RB25 but here is one:
Its a built motor though, but it also has alot of restrictions.
For a internally gated setup the flow of the engine system is strongly dependent on the exhaust, so in a common scenario it will be what ever an 3 inches exhaust can flow, and that is usually up to around 400HP wheels. Anything rated to higher power levels is recommended to work with an external gate unless can run a big straight pipe to ground.
Far as power and response, I recommend our latest Ball bearing ATR43SAT series.  ATR45SAT (Note: ATR45 (3582) and ATR45SAT are very different turbos) is capable of making alot more power if externally gated is in mind.
ATR43G3SAT CBB Power 317rwkws P98 fuel internally gated
ATR43G3SAT CBB Boost 317rwkws P98 fuel internally gated
19 hours ago, Die$eL said:
The car is basically stock.
There's a lot of recommendations made that are going to require a $10k minimum spend to make the car capable of running reliably.  They're not bad ideas, just failing to acknowledge the financials.
Until OP is prepared/able to pony up for all the regular associated upgrades - ECU, cooler, proper exhaust, fuel system, clutch, rubber, brakes, suspension I'd say he's best to stick with a small close to stock sized replacement running low boost eg 10psi and keep motoring until the funds are there.
  • Like 1
Well, if you want to be sensible about it, it doesn't make any sense to buy the "wrong" turbo for his end goal now, just so it won't overrun his injectors and AFM.  Piggie's original recommendation (and mine) implied that he would buy the turbo he wanted AND make sure he had the fuel and management also, although I'll admit that we didn't make that real clear.
Needless to say, the whole exercise is probably best reconsidered.  What the OP really needs is a 2nd hand stock R33 turbo to throw back onto the car until he is actually ready to do the needful.
  • Like 1
But it's SAU, when does anyone listen to sensible recommendations?
My pick would be:
  • Top feed conversion
  • External FPR
  • Wallah bro 460
  • Splitfires
  • Nistune with Feature Pack
  • Continental Flex Sensor
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
  • Traction Rods, Rear camber arms, castor rods, HICAS eliminator
  • Intima SR brake pads all round
Call it a day, 300kW street beast.
My pick would be:
  • External FPR
  • Wallah bro 460
  • Splitfires
  • EBC of some sort
  • HG G3 Highflow
  • Decent FMIC
  • Decent TBE
  • 1.5/2 way LSD
  • Decent coilovers
Pretty much just described my car, almost. Can confirm its an awesome setup on E85.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
