6 minutes ago, GTofuS-T said:
has any ever had their 90's era car air-bag go off? wondering if they even work at all
Edit: I've hit a few kangaroos and never set anything off, but not sure how much of an impact is required.
I’m no air bag expert but I have been in a accident where an air bag was deployed so can speak from experience that it went off when most of the front was totally damaged.
They are supposed to last a very long time whatever that equates to your guess is good as mine.
6 minutes ago, Dose Pipe Sutututu said:
Then you go remove your airbag because you don't want to die, just to be defected by the cops and fail your inspection LOL... can't win.
considering the replacement for affected cars is reportedly an 18 months wait, and recently a guy died from one of these days or weeks from replacement, you could argue (probably in court) that removal was justified for fear of safety?
This is exactly why I feel uneasy as we don’t know for sure whether our cars are affected or not and no one seems to know for sure.
So, in Australian delivered cars it goes back to 1999 (E46 BMW). https://www.productsafety.gov.au/recalls/compulsory-takata-airbag-recall/takata-airbag-recalls-list
Interestingly, no E90's are affected.
Wikipedia has more info but fails to cover the vehicles affected - perhaps a liability issue? https://en.wikipedia.org/wiki/Takata_Corporation#Cars_affected
Hey mate, thanks for the info. Still doesn’t specifically exclude our cars but it does tend to suggest we are not.
One can only hope we don’t find out the hard way!
Considering the number of these airbags in circulation and only ~25 deaths and ~250 injuries your odds are pretty good.
1 hour ago, r32-25t said:
I don’t understand how this issues goes so far back and they’ve only worked it out 18 or so months ago
Yeah me neither, clearly some ball dropping going on.
Yep agreed but I would hate to be the 1-5% chance with a hole through my face.
  • Like 1
3 hours ago, PranK said:
Hmmmm the other link doesn't mention e90s at all.
The link in your post further up the page lists E90s - it shows as "E8x 1 series, E83 X3 and E9x 3 series" - thats the link I followed to get the page I linked.
My airbag was replaced a few months ago by BMW. Is your steering wheel a BMW supplied one?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
