So I currently have an R32 GTR making 310rwkw's @ 18-20psi (98ron) with a Nistune ECU.
For my next stage of modifications I'm looking to get into the high 300rwkws bracket but was hoping to keep my Nistune.
In speaking to my tuner he's sceptical that it will be up to the task, I understand that a Haltech or Link etc. will do the job better/easier but I would've thought the Nistune would still be up to the task?!?
Current mods and mods to undertake:
  • Garrett -7 turbos (rebuilding to -9 spec)
  • Nistune ECU (hoping to keep)
  • Nismo AFMS (hoping to keep)
  • stock airbox (hoping to keep)
  • 660cc injectors (upgrading to 1250cc)
  • Blitz DSBC (hoping to keep)
  • 98ron (upgrading to E85)
  • stock head gasket (upgrading to metal)
  • stock head studs (upgrading to ARP 2000)
  • stock cooler (upgrading to Plazmaman)
  • stock cams (upgrading to Kelford)
  • stock valve springs (upgrading to BC)
  • Walbro 460 (hoping to keep)
  • Extreme HD clutch (upgrading to Nismo twin plate)
…and yes before anyone chimes in I do realise this could be achieved quite easily with a nice single turbo ;)
The ECU won't be the problem here. The only problem would be whether the AFM's run out of flow.
Given I've literally never read a scenario where someone running -9's has a problem with AFM's running out of flow you will be entirely fine.
The Nistune can do full flex now, as well as run E85 so don't let that one get in the way either if you want to head down that path.
  • Like 1
Exactly what my thought process was going into this......
Cheers!
Yuh.  So long as the pulse width and spark can be controlled, there's no reason to not use Nistune.  By the way, that "so long as" condition is entirely rhetorical.  Of course it can.
The limitations starts to come down to things like the CAS, more than the ECU or even the AFMs.  You can upgrade the AFMs easily enough.  But you can't use a better crank trigger against the Nistune.  It would be good for Matt to make a feature pack that allows the ECU to use simpler and more robust trigger patterns though.
  • Like 3
Makes plenty of sense to me..... ?
Very interested in the outcome as your before / after have similarities with my current setup and what I intend on upgrading to.
Isn't high 300s optimistic for -9s though? I thought that 350ish was typical for -9s.
You haven't mentioned the exhaust setup but I assume that you have a high flowing large diameter zorst?
Hey Rob,
I too thought this initially was probably a little optimistic but I'm basing my build roughly of what ActionDan achieved and from memory he netted around 380rwkws...
Remember this will be E85 and aftermarket cams/valve springs...
My issue is going to be more along the lines of my intake side of things I reckon, I want to retain the standard airbox, intake piping, Nismo AFM's etc... Basically pop the bonnet and it look standard to the untrained eye...
and yes I have a full 3.5" custom exhaust setup...
Edited by mr_rbman
  • Like 1
5 minutes ago, niZmO_Man said:
Nismo AFM = Z32 guts in standard AFM body IIRC
Not quite.  It's supposed to be 65mm body (same as normal RB26) but with flow vs. voltage curve that is same as Z32.  So the internals aren't "the same as" Z32, because that wouldn't work.  But the combo of the small body and the sensor calibration makes them "look like" a Z32 to an ECU.
  • Like 2
Nice zorst!
I had a good look at ActionDan's build and asked a few follow up questions as he had attained some good numbers all right.
I will be looking at similar mods: Kelford Cams, HPI dumps, custom exhaust, bigger injectors, Plazmaman cooler, AC Delco coilpacks etc. But like you, trying to retain the stock engine bay look with factory airbox / snorkel, piping, Nismo AFMs etc.
Will see how it all goes. I have 308KW at the moment which was fine when the original build was done as the drivetrain was ancient but I now have a brand new gearbox / clutch, recoed tailshaft and the diffs are next so happy to have a bit more torque.
I have similar set up as yours and also getting about ~300rwkw on 17psi with 93 AKI (not sure what that is in RON), so I'm interested to see your new results.
I'm confident Nistune won't be an issue for you, and my tuner had done plenty of +400kw Z32s on Nistune with stock Z32 AFMs so I'm sure your other hardware is up to the task as well.
Ah right, I read about them a long time ago, guess time degrades memory.
Also I believe MINE's made basically the same thing.
MINE's made the same thing, but with RB25 AFM internals in stock RB26 65mm housing.
On 7/10/2018 at 7:17 PM, BakemonoRicer said:
Spending all that extra money you are nuts to retain twins.
Those things were in fashion last century
Seriously, go an EFR! Those things are magic and you wont be wasting your money doing things twice!!
Refer to last line of original post.... ;)
surprised it actually took 16 odd posts for it to be mentioned :-P
  • Haha 1
  • 3 months later...
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
