1 hour ago, thenixtone said:
Hey guys,
So I was defected tonight lol, for my 50/50 blow off valve and carbon fiber bonnet.
How easy is it to fix the bov problem / what would i need? I have no idea..
Cheers..
How a out a stock blow off valve ?
man I am smart. Why are you confused?
  • Like 1
I'm making like 19psi, arent the stock ones rated to 8psi or something??
Well no, the stock one isn't rated. But have you considered swapping stuff to get the defect off then putting it back on after?
I think it has been done before, a cheeky little trick car guys do.
  • Like 1
loooool...you don't have ANY ideas? not even one? like putting fkn stock parts back on to clear the defect??
I know, i'm a genius, a real out of the box thinker.
Only really 2 options
1. Easy cheap fix
Stututututu
2. More expensive fix with the added benifit of reliability = LS swap
Seriously, if you have maaaaad pipe work and "stuff" post a pick of what you have so people know what you are dealing with
Go option 1
14 hours ago, thenixtone said:
Hey guys,
Cheers..
Hello thenixtone,
I think some places do full recirculation blow off valves. I think they got you on venting to atmosphere. Have a quick look at turbosmart webpage.
And maybe visit a wrecker to get your hands on a factory bonnet.
Sounds like you got a lot of leniency, count your blessings bruv.
Are you talking about your BOV or your wastegate?  I think you have the two confused.
A std BOV will work for your setup just as easy as some aftermarket setup, just won't look as bling!!!
2 hours ago, Ben C34 said:
Anyway good work, acting dumb can help with cops, good work staying committed.
I don't have any stock parts as the car came like this, so rather than waste money on stock parts that aren't good enough, I'd want to get the right thing. 9k posts and shitting on people with less experience, gotta love the community, not the first time you've been a tosswank on here though is it
So what is your actual question? The Problem you can't figure out? You want to find a plumback blow off valve to suit 18psi?have you tried at all or just hoping others will read your mind and tell you exactly what to do.
Your post really doesn't say much, certainly doesn't imply you want to fix things properly and not just do a stock swap over.
If this is your first time with a defect get ready for a world of pain on inspection.
So what is your question?  Is it will a stock bov work with the tune and/or boost level you have?
If the answer is more than your boost level then get a stock item.
If the answer if vague and or lower then in the olden days people used BOV's from GT-R's which can look pretty stock.
I dont know the answer as I have no clue what motor you have.
I suspect that the bonnet and the bov will be the tip of an unhappy iceberg when the car gets properly inspected, however.
While I dont disagree with your point above it helps to give some context to your questions.  This being th einternet things can get misconstrued and more information helps make it look like whoever is asking the question will make an effort to follow through with a solution.
You want help ask sensible questions and listen to the answers.
Stock bov is good enough.
Metal bonnet is good enough. Carbon fibre bonnets are considered a danger (do the research to find out why).
that's somewhat fair enough, but it's best to do some research and try to help yourself first though. It's not a 'new guy' thing though, plenty of newbies on here get good help n advice.
And if you drive a modified car, getting pulled off by the cops (off the road, i mean) is always a risk. Check over your car, see what mods it has, check the NCOP and see if you need to change it or get a mod plate, or run the risk and accept the consequences.
The Turbosmart plumb back Kompact Bov for a RB25 is what you want.
Alternatively, swapping a stock one on for the inspection is an issue. If you want 'performance' over the stock BOV and the ability to never worry again about legalities, at the cost of 'wooshy sounds' the kompact plumb back is what you want,
  • Like 2
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
