Hi folks, would you know what size wheel is on Garage Yoshida's shop car?  More specifically the width.  I look up BBS' lineup and that looks to be their RI-A wheel, either 18x9.5 +22 or 18x10.5 +18.  I first thought it must be the 9.5" because it's on R32, but looking at the front wheel to fender gap I am not so sure.
Rolling shot starts at 0:26 mark.
Edited by TXSquirrel
On 3/3/2020 at 7:54 PM, niZmO_Man said:
Judging from the stretched tyres, 10.5 with 265 wide tyres.
I always wonder how could R32 run 10.5" wide wheels.  I have 17x9 +22 right now and it's already lined right up to the fender in the rear.  Front strangely still has space though.
I have 10" +20 with 275/35 Hankook RS3
All guards rolled
-2.5deg camber front
-1.5deg camber rear
Just fits haha. I want to go 285/30 as current tyres are a little stretched.
but yes, for a street setup, non vapegram spec, 9" +20's is plenty
  • 3 weeks later...
Waiting for my car to arrive from Japan later this month and i'm looking at 3piece wheels.
4door 32 people how would 18x8.5 et29 & 18x9.5 et29 fit? Im after a tight fitment & I dont mind running a small amount of stretch.
See pictures below.
These are the wheels I am about to buy. I have a r32 sedan type m, so it has the bigger brakes & 5 stud obvs.
You guys reckon they will clear breaks fine? its hard to get all this right without having the car hah. Gonna be running the car fairly low too or what ever it takes to get tight fitment between tyre and fenders ?
On 09/04/2020 at 6:49 PM, Frostyr33 said:
Skyline model = BCNR33 GTR
Wheel diameter = 18”
Wheel width =10”
Wheel offset =+20
Tyre size =265 / 40 / 18
Modifications to fit = Ohlins coil overs
Are you sure it's not 265/35, because why the hell would you go a 265/40R18 ? That's a 20 - 25mm + larger rolling diameter (670mm) than the factory range of 235/45R17 to 245/45R17 (642mm - 651mm).
265/35 or 275/35 on 18's on a 33 or 34 generally if you want your Speedo to be at all accurate, as above will read about 5% under, as in reading 95 when you're really at 100.
On 3/30/2020 at 9:56 AM, Adz2332 said:
what was that website called that has pics of cars with the rim specs they are running etc?
have a stinger and looking for pics of a few wheels in the odd offsets they will need to be
https://www.rimtuck.com/
?? Perfect. I noticed they are AD08R. Interestingly, which I just found out when I fitted them to my 32R, is that they are a bloody big tyre.
I have Advan V103 on my 33R in 275/35R18 and recently fitted the Advan AD08R on the 32R in 265/35R18 - the 265 is a much bigger / wider tyre than the 275. Great for a 33, but pushing it on the 32 without a fair bit of camber.
Has anyone else found this with the AD08R being not comparable other tyres, as in, a LOT wider for a given aspect ratio ?
Hey guys I need emergency help!
I currently have an R34 GTT with Tein Coilovers
Looking at buying LMGT4 in 19”
FRONT: 19x8.5 +25 with 245/35/19 tyre
REAR : 19x9.5 +30 with 275/35/19 tyre
With these fit without rolling guards or anything?
Screenshot is vs current setup which has only slight rubbing at the moment on full lock!!
Edited by BlazenR34
7 hours ago, Predator1 said:
Seeing that you're going from a high to lower offset wheel, I would suspect they would rub a bit more. What's your ride heigt and camber?
Not sure about camber atm but the measurement from the ground to the top of the wheel arch is 650mm.
Does anyone know what the perfect fitment/rim size/offset for LMGT4’s would be in 18” and 19” for flush fitment to the guards.
Edited by BlazenR34
Newbie to the forum here. Looking for some advice from someone who has experience with 34 GTT 2 door's.
Looking at 18x8.5 +30 Fronts, 18x8.5 +35 Rears.
Car is lowered on coil overs, no guard roll. Will this be a good fitment? After a very slight poke if possible. Looking for semi-aggressive fit without drawing to much attention from the po po. Don't want to roll guards and have to worry about scrubbing.
Prob go 235's front and 265's rear if that fits. Would prefer 255's rear but its uncommon size.
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
