Hi folks, would you know what size wheel is on Garage Yoshida's shop car?  More specifically the width.  I look up BBS' lineup and that looks to be their RI-A wheel, either 18x9.5 +22 or 18x10.5 +18.  I first thought it must be the 9.5" because it's on R32, but looking at the front wheel to fender gap I am not so sure.
Rolling shot starts at 0:26 mark.
Edited by TXSquirrel
On 3/3/2020 at 7:54 PM, niZmO_Man said:
Judging from the stretched tyres, 10.5 with 265 wide tyres.
I always wonder how could R32 run 10.5" wide wheels.  I have 17x9 +22 right now and it's already lined right up to the fender in the rear.  Front strangely still has space though.
I have 10" +20 with 275/35 Hankook RS3
All guards rolled
-2.5deg camber front
-1.5deg camber rear
Just fits haha. I want to go 285/30 as current tyres are a little stretched.
but yes, for a street setup, non vapegram spec, 9" +20's is plenty
  • 3 weeks later...
Waiting for my car to arrive from Japan later this month and i'm looking at 3piece wheels.
4door 32 people how would 18x8.5 et29 & 18x9.5 et29 fit? Im after a tight fitment & I dont mind running a small amount of stretch.
See pictures below.
These are the wheels I am about to buy. I have a r32 sedan type m, so it has the bigger brakes & 5 stud obvs.
You guys reckon they will clear breaks fine? its hard to get all this right without having the car hah. Gonna be running the car fairly low too or what ever it takes to get tight fitment between tyre and fenders ?
On 09/04/2020 at 6:49 PM, Frostyr33 said:
Skyline model = BCNR33 GTR
Wheel diameter = 18”
Wheel width =10”
Wheel offset =+20
Tyre size =265 / 40 / 18
Modifications to fit = Ohlins coil overs
Are you sure it's not 265/35, because why the hell would you go a 265/40R18 ? That's a 20 - 25mm + larger rolling diameter (670mm) than the factory range of 235/45R17 to 245/45R17 (642mm - 651mm).
265/35 or 275/35 on 18's on a 33 or 34 generally if you want your Speedo to be at all accurate, as above will read about 5% under, as in reading 95 when you're really at 100.
On 3/30/2020 at 9:56 AM, Adz2332 said:
what was that website called that has pics of cars with the rim specs they are running etc?
have a stinger and looking for pics of a few wheels in the odd offsets they will need to be
https://www.rimtuck.com/
?? Perfect. I noticed they are AD08R. Interestingly, which I just found out when I fitted them to my 32R, is that they are a bloody big tyre.
I have Advan V103 on my 33R in 275/35R18 and recently fitted the Advan AD08R on the 32R in 265/35R18 - the 265 is a much bigger / wider tyre than the 275. Great for a 33, but pushing it on the 32 without a fair bit of camber.
Has anyone else found this with the AD08R being not comparable other tyres, as in, a LOT wider for a given aspect ratio ?
Hey guys I need emergency help!
I currently have an R34 GTT with Tein Coilovers
Looking at buying LMGT4 in 19”
FRONT: 19x8.5 +25 with 245/35/19 tyre
REAR : 19x9.5 +30 with 275/35/19 tyre
With these fit without rolling guards or anything?
Screenshot is vs current setup which has only slight rubbing at the moment on full lock!!
Edited by BlazenR34
7 hours ago, Predator1 said:
Seeing that you're going from a high to lower offset wheel, I would suspect they would rub a bit more. What's your ride heigt and camber?
Not sure about camber atm but the measurement from the ground to the top of the wheel arch is 650mm.
Does anyone know what the perfect fitment/rim size/offset for LMGT4’s would be in 18” and 19” for flush fitment to the guards.
Edited by BlazenR34
Newbie to the forum here. Looking for some advice from someone who has experience with 34 GTT 2 door's.
Looking at 18x8.5 +30 Fronts, 18x8.5 +35 Rears.
Car is lowered on coil overs, no guard roll. Will this be a good fitment? After a very slight poke if possible. Looking for semi-aggressive fit without drawing to much attention from the po po. Don't want to roll guards and have to worry about scrubbing.
Prob go 235's front and 265's rear if that fits. Would prefer 255's rear but its uncommon size.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
