  • Replies 286
I'm keen as mustard form this.
I've just spent the last 2 days polishing and detailing my car, and she looks better than she ever has before.
Wow... ...Shiny...
I always have people tell me how clean my car looks... ...but at the moment she's a dirty as a hooker on a monday morning...
I was hoping I would get my car back today for the dyno day, but looks like the workshop is screwing me around..
I got told that I'd get a call but no go! Went in and the guy wasn't there.
Hopefully there is one on again soon.. Was hoping to meet some people from SAU! -_-"
nah another blue s13 rocked up right after you left... i forgot what it made... but ya it was 1kw more than yours
sorry :)
hahaha :P so what did your car make then? ;)
what was the most powerful rb20?
202kw's for me. Not bad but there are plenty of guys making more than that.
Thanks to the organisers. I had fun except the defect on the way down there.
Who won the 'guess the kw' comp?
the r31 got 233 rwkw's
Yup, the oldest skyline at the day held its own against its larger capacity brothers and all with a stock turbo. :down:
Another RB20 came very close that had a 2535, nice curve as well.
Then there was a white 32 with an RB20.......that began its ramp up with af/r's starting at 17:1 and dissapearing off the top of the chart. Operator backed right off and I assume he thought something was amiss as they redid the sniffer and started again to get the same result.
Engine was obviously a time bomb but owner is lucky he spent the couple dollars to put it on as it has saved him an engine.....if its not already too late.
Edited by FATGTS-R
That was my R32 with the 2535...made 223.4rwkw...turns out my boost gauge was inaccurate and it was only running 17psi...should have been 19-20psi...but i'm happy with the result regardless...in the end...it was a great day...cheers all...
Oh...and go the rb20!! :)
Edited by limpus
What a great turn out!
Some spectacular cars out there today! Good to meet some of the memebers on here in person. Would have like to see the Millenium Jade coloured R34 GTR V-Spec II Nur run a dyno.
Did Snowman run? If so what was his power output?
The Blk R34 GTT with the GTR kit and blk wheels was sick! I followed you for abit down Springvale Rd.
So many cars too may to mention. GREAT DAY!
PS took afew pics.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
