Whens everyone getting up to High Country? I expect to be up there mid afternoon Thursday. Am driving the Zero car, and rather than a renter we were offered Barry's VE ute. Looking forward to painting some lines :) Thanks to Capt Fathom for all his help too :)
The car has actually got a developement KW spring and shock setup in it, and I sent some bars down for it this week. We'll have some fun while tuning it in for Barry's next event. For anyone I've not met from the board, come say hi! Your shout!
We are heading up tomorrow evening as we are booked in for scruitineering Thursday morning. Will be sure to say g'day - determined to make it to the Targa Bar this time around :)
Putting the finishing touches on the car today and its all come together really well. Can't wait to get back out there!
We will be there from Thursday arvo.
Following our small mishap (split transfer case anyone?) a few weeks back, the little cheater car is all sweet. Feels better than ever with the new wheel/brake package but could still do with some moisture to bring the field back to us :whistling:
Woo, I must say, painting lines in someone elses car produces uncontrollable giggles...and when they're also providing the rubber... :3some:
Especially when we have 4 spare Tyres in the tray :)
How'd the case split?
Not 100% sure. It was such a mess that it was hard to pintoint exactly what let go, but the possibilities we have are:
- pre-load set too high in the front diff (we've got our setup to the point where the car is working really well and have a heap more grip than previously. With this extra grip and a tight front diff something had to give)
- hairline crack in pinion (this might have happened in the actual let-go)
- I was chasing another Evo with 60 more HP and slicks so the most likely cause is that Im just tough on the gear :domokun:
EDIT that. Unfortunately we now seem to have a lot less tyres that are actually worthy of bolting onto the car, so now I must actually conserve tyres. The four that are on it are "ok" I've been told. The four that were to be spares are one the canvas.
Doh.
Car's on the trailer now, planning to leave from Sydney around 2am to get down there early afternoon. Planning to drop the car off after scrutineering then take the Patrol out for a bit of recce.
Quite excited for this after our dnf at TT earlier in the year. Have been working my a** off to pay for the engine since then so about time for a break! Weather forecast looks promising for now, 30% chance rain Fri, 10% Sat and 30% Sun.
We are out unfortunately with engine trouble. Played it pretty safe all day but the car has been feeling down on go. Something popped near the top of the hill - hopefully not too serious. Also need to do a bit of work getting the suspension set up - not quite confidence inspiring in the faster stuff yet. One day Thc, one day....
Good luck to everyone tomorrow!
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
