Its very unfortunate that Brae have finally gaven up on the simple log manifold design as cyc No. 4 can not be bent that far to suit stock position. I will speak to few other welders and see what other possibilities are. But for the time been I will be assembling my car with what I've got and have that back doing its jobs soon as possible.
surely you could use whoever makes your rear housings and get them to make a modified version of the cast iron hks manifold
(make it so that it bolts on easily)
If the goal is stock location the HKS low mount isn't going to be the answer.
stock location won't be needed if its gonna come as a whole kit (dump included too)
Looks like I might have to go high mount to keep the costs down. apparently the side mount takes too much efforts to complete. There's one more welder who'm happy to give it a shot, we see how it goes.
What's the verdict on opening up the stock exhaust manifold a bit? Possible? Useful?
Or is that for another thread?
Is the manifold you posted on the last page a more expensive design or mounts the Turbo in a different location?
That is a $1100 manifold, the log manifold will have 123 goes into one plus and 345 in another. How ever there isn't enough room to merge 345 as the steam pipe bends are too big. If you go back and have a look at how my manifold is constructed, there are lots of efforts and man hours spent.
Yes by die-grinding stock manifold would help on picking up 17kws, pumps it to 297rwkws internally gated.
Do you have the ability to open up stock manifolds? If so, why not try and source say five stock manifolds, prep them and then sell them as part of a kit on an exchange basis? Charge people an extra $100 that you'll refund once they send in their stock manifold.
Might be easier and a shed load cheaper than trying to get your own steam pipe manifold sorted?
Just a thought.
^^^ good idea. I pulled a tonne out of mine. Surprising how poorly the ports matched the head. Plus the collector flange is much smaller than the gasket.
Whoever purchased a ss2 running ext gate is in for a treat.
Just got my car tuned at chequered tuning
Initially got 295 but wanted to be safe so turned back the timing.
So final =
276rwkw
18psi tapering to 16psi
Full boost at 3800
There is an abundance of wheel spin and really quick acceleration . Very happy.
So final =
276rwkw
Full boost at 3800
cool, do you think its laggy now?, Stao ran a bit more boost didn't he..21psi tapering to..? be good to see the dyno
sheet
Edited by jet_r31
Yes, In my opinion it is still laggy. But that is greatly outweighed by the power it produces and the smile it puts on my face on boost. Mind you it has performed just as well if not better than Stao has described it would so the turbo for what it is is great.
Mods are as follows
Z32
3" exhaust, no cat, 1 muffler (home-made)
600x400 bar and plate cooler with return flow piping, assuming its home-brand as i only paid $50.
Tial 44mm gate (17.64PSI)
SS2 0.82 type b
52mm Radiator
bcpr7es copper plugs
DW 740cc Injectors accompanied by a Bosch 044 (intank)
EVERYTHING else is standard
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
