Its very unfortunate that Brae have finally gaven up on the simple log manifold design as cyc No. 4 can not be bent that far to suit stock position. I will speak to few other welders and see what other possibilities are. But for the time been I will be assembling my car with what I've got and have that back doing its jobs soon as possible.
surely you could use whoever makes your rear housings and get them to make a modified version of the cast iron hks manifold
(make it so that it bolts on easily)
If the goal is stock location the HKS low mount isn't going to be the answer.
stock location won't be needed if its gonna come as a whole kit (dump included too)
Looks like I might have to go high mount to keep the costs down. apparently the side mount takes too much efforts to complete. There's one more welder who'm happy to give it a shot, we see how it goes.
What's the verdict on opening up the stock exhaust manifold a bit? Possible? Useful?
Or is that for another thread?
Is the manifold you posted on the last page a more expensive design or mounts the Turbo in a different location?
That is a $1100 manifold, the log manifold will have 123 goes into one plus and 345 in another. How ever there isn't enough room to merge 345 as the steam pipe bends are too big. If you go back and have a look at how my manifold is constructed, there are lots of efforts and man hours spent.
Yes by die-grinding stock manifold would help on picking up 17kws, pumps it to 297rwkws internally gated.
Do you have the ability to open up stock manifolds? If so, why not try and source say five stock manifolds, prep them and then sell them as part of a kit on an exchange basis? Charge people an extra $100 that you'll refund once they send in their stock manifold.
Might be easier and a shed load cheaper than trying to get your own steam pipe manifold sorted?
Just a thought.
^^^ good idea. I pulled a tonne out of mine. Surprising how poorly the ports matched the head. Plus the collector flange is much smaller than the gasket.
Whoever purchased a ss2 running ext gate is in for a treat.
Just got my car tuned at chequered tuning
Initially got 295 but wanted to be safe so turned back the timing.
So final =
276rwkw
18psi tapering to 16psi
Full boost at 3800
There is an abundance of wheel spin and really quick acceleration . Very happy.
So final =
276rwkw
Full boost at 3800
cool, do you think its laggy now?, Stao ran a bit more boost didn't he..21psi tapering to..? be good to see the dyno
sheet
Edited by jet_r31
Yes, In my opinion it is still laggy. But that is greatly outweighed by the power it produces and the smile it puts on my face on boost. Mind you it has performed just as well if not better than Stao has described it would so the turbo for what it is is great.
Mods are as follows
Z32
3" exhaust, no cat, 1 muffler (home-made)
600x400 bar and plate cooler with return flow piping, assuming its home-brand as i only paid $50.
Tial 44mm gate (17.64PSI)
SS2 0.82 type b
52mm Radiator
bcpr7es copper plugs
DW 740cc Injectors accompanied by a Bosch 044 (intank)
EVERYTHING else is standard
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
