The SS15 high flow would work extremely well, Will be suited between 200~230rwkws region:
I can confirm this, I've got one on my tarmac rally car it's fantastic. Topped out at 220kw@20psi but the boost response is fantastic.
Edited by Komdotkom
I guess we can call the new turbo ATR45.5SAT model. I'm keen to see the result.
The Yellow R34 No.2 didn't go so well unfortunately, and we had to sort out a bunch of little problems with installation as well as getting the car running properly, there is still issues on ECU communicating with the boost solenoid, we run out time and have to finish off the tune another day.
But yes it is very responsive, notice the linear power and torque before 3000RPM:
2ndly, because I'm now using a JJR's normal front mount cooler kit instead of the return flow. Boost shoot easily over 20psi. I'm sure that 90 degrees bend would be cause of the boost tapper on earlier runs.
But either way, special application turbo for return flow cooled RB25dets are available.
yea this car's the worst out of all, still alot of little stuff to fix, while I've already made the next booking sitting around for 40 mints, next tune is booked 3 weeks away. hopefully all sorted by then.
any ideas why my boost would fluctuate from 15-17 psi back and forth?
changed to a 15psi actuator and this started happening, should i add more or less preload?
previous actuator did not have this issue.
no boost controller installed, running gate pressure
updating some 1JZ results. Those are from 1JZGTE Chasers:
This is 292rwkws on 19psi on our TD06SL205 Turbocharger externally gated, P98 fuel, Unopened engine:
And this is using a high flowed factory CT15B on E85 fuel making 321rwkws.
Little update. The R34's definitely not going as smooth as any of the other cars I've modified. The new car's finally made it self all working today on the dyno. It hits a boost restriction which boost curve went flat at 19psi on 90% ebc duty, how ever the pressure before intercooler is showing a boost curve that kept on clamming all the way up to 24psi.
After setting EBC on 100% duty after 4000RPM, and there is still a 4psi pressure drop. Didn't got up to expectations but definitely better then the 9psi drop that I've had with the return flow kit. Its currently using a 600x300x68mm Takashi cooler, I will be upgrading it to 600x300x100mm and hopefully reduces the percentage of pressure drop.
I have never experienced similar issues on my R33, S14 or the R33-GTR, but to both of my R34s.
That R34 made 425rwkws earlier did not have this issue however, by using a RB26 inlet manifold. I'm unsure if it is related to the actual design of the inlet manifold, if so I might have to make a group of special application turbos just for R34s.
Power stays 267rwkws @ 20psi, basically made no differences apart from lag using a much larger turbo.
Boost curve before cooler (20psi) and after throttle body (24psi) at 100% EBC duty
Hmmm....interesting. I've got your ATR43 G4 going on my NEO in the next few weeks. Will be interesting to see if I suffer similar issues.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
