The SS15 high flow would work extremely well, Will be suited between 200~230rwkws region:
I can confirm this, I've got one on my tarmac rally car it's fantastic. Topped out at 220kw@20psi but the boost response is fantastic.
Edited by Komdotkom
I guess we can call the new turbo ATR45.5SAT model. I'm keen to see the result.
The Yellow R34 No.2 didn't go so well unfortunately, and we had to sort out a bunch of little problems with installation as well as getting the car running properly, there is still issues on ECU communicating with the boost solenoid, we run out time and have to finish off the tune another day.
But yes it is very responsive, notice the linear power and torque before 3000RPM:
2ndly, because I'm now using a JJR's normal front mount cooler kit instead of the return flow. Boost shoot easily over 20psi. I'm sure that 90 degrees bend would be cause of the boost tapper on earlier runs.
But either way, special application turbo for return flow cooled RB25dets are available.
yea this car's the worst out of all, still alot of little stuff to fix, while I've already made the next booking sitting around for 40 mints, next tune is booked 3 weeks away. hopefully all sorted by then.
any ideas why my boost would fluctuate from 15-17 psi back and forth?
changed to a 15psi actuator and this started happening, should i add more or less preload?
previous actuator did not have this issue.
no boost controller installed, running gate pressure
updating some 1JZ results. Those are from 1JZGTE Chasers:
This is 292rwkws on 19psi on our TD06SL205 Turbocharger externally gated, P98 fuel, Unopened engine:
And this is using a high flowed factory CT15B on E85 fuel making 321rwkws.
Little update. The R34's definitely not going as smooth as any of the other cars I've modified. The new car's finally made it self all working today on the dyno. It hits a boost restriction which boost curve went flat at 19psi on 90% ebc duty, how ever the pressure before intercooler is showing a boost curve that kept on clamming all the way up to 24psi.
After setting EBC on 100% duty after 4000RPM, and there is still a 4psi pressure drop. Didn't got up to expectations but definitely better then the 9psi drop that I've had with the return flow kit. Its currently using a 600x300x68mm Takashi cooler, I will be upgrading it to 600x300x100mm and hopefully reduces the percentage of pressure drop.
I have never experienced similar issues on my R33, S14 or the R33-GTR, but to both of my R34s.
That R34 made 425rwkws earlier did not have this issue however, by using a RB26 inlet manifold. I'm unsure if it is related to the actual design of the inlet manifold, if so I might have to make a group of special application turbos just for R34s.
Power stays 267rwkws @ 20psi, basically made no differences apart from lag using a much larger turbo.
Boost curve before cooler (20psi) and after throttle body (24psi) at 100% EBC duty
Hmmm....interesting. I've got your ATR43 G4 going on my NEO in the next few weeks. Will be interesting to see if I suffer similar issues.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
