Roughly what size turbo is that? Keeping in mind that it is going on an RB20. Only wanting absolute max 250ish kW to keep response as best as possible.
Yes can build u an atr43g2 in cbb model for rb20det, that will be responsive and max towards 250rwkws regions
Stao what version of the Atr45 do i have? i got it in dec 2013.
is it even worst then the 1st rev of the atr45sat?
do you have a graph that compares my old one to the newest?
And how much to upgrade or change to the latest?
  • Like 1
The ATR45 is a 3582 equivalent in .82 rear. It's good size turbo for a 3L bottom. The new one is a very different turbo and nothing interchangeable. Best sell that and we can build you a ball bearing one new from scratch.
On 9/16/2016 at 5:20 PM, Dose Pipe Sutututu said:
extremely funny looking graph :)
Yep, Seems the engine had broken ringland's at the time thanks to a bad 'run in tune'
Had no signs or anything obvious until after this tune. (different tuners)
New version is a very different turbo.
Thanks Stao. Is if possible to build the new SS2 to the old dimensions so that it's a drop-in replacement?
I think Johnny said you need to adjust and rotate the dump a bit to accommodate the new one.
When Tao and are selves put Are heads together and come up with the 6765 , bb core t4 split pole rear ! This should de an animal on the new set up !
Big thanks to hypergear as usual
stock Rb25 turbo for comparison
  • Like 3
29 minutes ago, 4bidn1 said:
I should really put my glasses on before typing on my phone ?.
Thats not even English
Lol...did you use talk to text?  Makes sense then being you're from Radelaide.  I'm going to call you Christopher Pyne from now on :laugh:
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
