@V28VX37 There are no oil galleries inside comp cover. if engine rocket cover breathers are plumbed into the induction pipe. remove them and that bit of residue should clear.
For the  1hz cruiser we can high flow your stock turbocharger using G1 profile, its quite response with plenty of torque. It does need water and oil lines, everything else bolt back on with no fabrications.
  • Like 1
Thanks Tao, I was wondering about that, makes sense. Yes it's got the standard breather setup plumbed into (Scotty's) induction pipe.
Looks like the engine might be breathing a bit more oil then after the recent head gasket change. Should I be looking at a catch can?
Also if the turbo oil seal was damaged, I'm guessing it would be leaking at the core right (not at the comp cover)?
The seals are SS C clips, they don't wear unless of a thrust play, means turbo would've failed. The front collars are engineered to throw oil away from the centre shaft and the rear don't, so in case of turbo failures, the rear seal is likely to leak first.
  • Like 1
I've just installed a simple catch can setup and I'm still getting a drop of oil collecting at the bottom rear edge of the comp cover, it's really strange.
I've previously tightened all oil and coolant lines and the turbo core section seems dry as far as I can tell from above and below. I'm still getting good boost, so the turbo is definitely working.
Any other suggestions on what else could be causing a minor leak at the comp cover?
Hi guys,
Keen to share my results, hopefully they might help others in choosing their setup.
S1 RB25det, 2013 ATR43SS1PU turbo, stock manifolds, 3" exhaust 100cell cat, megasquirt ECU, splitfires, sard 850cc injectors, DW300 pump, undersized intercooler (high intake temps and around 4psi drop).
Graph shows 98 on gate pressure vs ethanol with a little more boost.
Edited by IT15ON
fixed attachment
  • Like 1
Looking for some feedback on my dyno graph. Is this normal because power and full boost seems to come on really late. Car is r33 gtst s2 manual
Mods:
-Hypergear op6 highflow ball bearing G3 profile.
-power fc
-xspurt 1000cc top feed injectors
-walbro 255lph fuel pump
-blitz return flow intercooler
-full 3 inch exhaust
- apexi pod and solid intake pipe mod
-splitfire coilpacks
- NGK sparkplugs 0.8mm
5886ddcc1f170_2017-01-2404_18_36.jpg.9c4
^ take it to a different tuner, also are you running a cat - if so which cat? plus need more boost
Cant really afford to get another tune. I had a chat to the tuner and he said theres nothing that can be really done and its just a laggy turbo. Im happy with 250rwkw i would just have liked full boost to come on earlier. Im pretty sure its a highflow cat not sure what brand though.
Also the wastegate actuator was set at 18psi. But it was opening up at around 13psi and they had to use a bleed valve to bring the boost up.
I've seen a tune file from said tuner from a car with similar mods. It was horrendous at the very least.
Also your cat is probably restrictive.
FWIW I've been happy with Chasers and Paul's always done a good job with my tune.
Check that cat, my car picked up about 25 rwkw going from X force 'high flow' to a proper Venom 100cell.
Edit: Mine's a 34 with Nistune not PowerFC
  • Like 1
Mods:
-power fc
What boost controller are you running?
Something is not right, I'm hitting 20psi with the OP6 highflow at 4900, and thats on my RB20 which is 500cc smaller and has no VCT.
With the OP6 High flow, Just check to make sure the actuator is preloaded and shut, leaks and active VCT. Alternatively you can send it back and swap the turbine housing to smaller 21U. The op6 should be making 20psi at 4100RPM on a R33 Rb25det engine and maxing towards 290rwkws.
A decent CAT really make that much difference :O??????? How would that compare to decat?
Where's the best place to pick up one of these venom 100cell cats?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
