Now available:
COIL PACK HARNESS - R32 GTST RB20DET - COMING SOON
COIL PACK HARNESS - SERIES 1 R33 GTST RB25DET- $100.00 delivered via express post.
COIL PACK HARNESS - SERIES 2 R33 GTST RB25DET - $105.00 delivered via express post.
COIL PACK HARNESS - R34 GTT RB2DET NEO - COMING SOON
COIL PACK HARNESS - R32 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R33 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R34 GTR RB26DETT - $115.00 delivered via express post.
COIL PACK HARNESS - 180SX/S13 CA18DET - $100.00 delivered via express post.
COIL PACK HARNESS - S13/S14 SR20DET - $110.00 delivered via express post.
COIL PACK HARNESS - S15 SR20DET - $115.00 delivered via express post.
All items are in stock in Australia and will be sent via express post.
CLICK HERE for more pics and details or to purchase.
Combine your order by purchasing a new set of Yellow Jackets Coils Packs and receive free shipping on the matching Coil Pack harness.
  • 1 month later...
  • Replies 217
Hi Paul
I remember a while ago there was some talk about Yellow Jacket Ignitors. Is there any update with these?
Thanks
I have them nearly ready for the R33 GTST but need to get the plug fitment better. They are currently too tight.
I need to get hold of some stock plugs or a stock ignitor so I can improve on this.
  • 3 months later...
S15 Yellow Jackets are now available for $340/set delivered.
Posted Image
Also available.....
Brand New Yellow Jackets T-Shirts for $25.00 delivered
Front print - Plain back.
100% pre-shrunk cotton.
Available in white only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
Posted Image
Now available:
Hi there!
Any news on whether the R34 GTT RB25DET Neo coil pack harness is available?
Unfortunately these arent going ahead as the manufacturers dont normally make them and if we were to go ahead Id need to order a minimum of 100 pcs. :(
Ok so I'll have to get them from Nissan I suppose, and connect them with the Yellow Jacket R34 GTT RB25DET coil packs (if you have any in stock)
Sorry I can help out with the harness. However, I definitely have the Yellow Jackets in stock and they will be sent out via express as soon as your payment has been received.
:cheers:
  • 3 weeks later...
  • 2 months later...
  • 4 weeks later...
Hi - can pm me the price for coil packs and harness? BNR32 GTR? - May want to get an item or 2 from your site as well... maybe can package the shipping? Please let me know.
Thanks!
Excellent seller and brilliant service - bought the harness - fits perfect - will definitely do business again! Cheers
Total price is $
Hello need a price for r33 gtr coil packs and harness posted to 2145
Total price is $540.00 including express post to 2145. :cheers:
  • 1 month later...
    • After throttle body? I’ve heard that you should not do that. Even if you look at the diagrams they show you that you should take boost from turbo.
    • What do you mean with ”hot side”?  From what I’ve heard is that you should take it as close to the turbo as possible?
    • Like on the intercooler pipe between turbo and intercooler?  Still weird why they don’t put an output on the turbo since you will need one. There is one for the RPM of the turbo..  are they doing this because they want you to take the boost reference from somewhere else except the turbo?
    • That wouldn’t work especially well? 🤔
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
