  • Replies 217
No worries mate just checked and it is $400 delivered. Must've been some error on my part. Just made a purchase. Thanks!
No probs and thanks for the purchase. Will ship these out to you today.
:cheers:
Hi Paul,
Looking at purchasing a set of YJ for R33 S2. I'm looking at running between 14-22psi through my new set up, now the obvious response from experienced RB owners is to purchase "S**** F***" blah blah blah I've read mixed feedback not to mention you standing by your product 100%.
Are your coils suitable to run and will they hold up to the higher psi range I will be pushing?
Thanks.
  • 4 weeks later...
Its finally time to fix my car. :)
How much for a set for 93 r33 s1 gtst please? Can u link the payment portal, that would be appreciated.
Edited by Cuz Bruz
Total price is $400 shipped via express post.
You can purchase from either of my websites:
Yellow Jackets
Performancewise
Performance-wise
Yellow Jackets
Performancewise
Performance-wise
Thanks for that, if I'm buying multiple items do i have to pay multiple shipping costs?
It depends which site you use....
Let me know what you are after and I can give you a combined price.
Just after these parts thanks :
YELLOW JACKETS COIL PACKS - YJ-RB202526-S1 $380.00 $20.00 (estimated) $400.00 1 NISMO OIL FILLER CAP - GOLD $25.00 $15.00 (estimated) $40.00 BRAND NEW BLITZ TYPE 1 RACING RADIATOR CAP $20.00 $15.00 (estimated) $35.00
Edited by Cuz Bruz
PM sent :cheers:
heaps in stock.
We also now carry the LS conversion kits which include a stealth black alloy mounting bracket, wiring specialties harness and YJ coils.
SEE HERE -
  • 1 year later...
Current price on six D585 coils?
couldnt seem to find it on your web site but maybe on eBay.
Price is $350 delivered via express post. Cheers.
Hi about 8 months ago i purchased some YJ coils for my rb25 s2 that was being rebuilt and on its most recent tune that happened about a month ago they said they couldnt push the boost over 18psi while making 360rwkw. Now im having to change my coils due to most recently a misfire at the top of the rev range indicating that the coils are beginning to break down? I have changed the spark plugs but to no avail. I am surpirsed at how the coils performed considering some peoples comments but they have been in the car all of 6 months and i think may be on there last legs
Please contact us if you are facing issues wit the coils.
They come with a 2 year warranty and we will be glad to help as best we can.
Following up my post from the other day i have recieved a refund and as a whole i was happy about the product and would still reccomend them for someone doing a build on the cheaper side as they are like half the cost of competitors and still perform well within what most people require just unfortunately for me i pushed them a little too hard
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
