After seeing the above, I got this one for $30 + postage.
http://www.ebay.com.au/itm/311514221310?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'll let you all know how it goes.
Also bought this about 12 months ago from Germany. Great for rivnuts in hard to get at places, does both nuts and threads.
Not sure if the address is the same business, I just found it and used it for the photo etc.
http://www.ebay.com.au/itm/Nutserts-Nutsert-Setting-Tool-M6-M12-Riv-Nut-Rivnuts-Rivet-Thinsheet-PNT210-/230986691661?hash=item35c7e1344d:m:mf7e5tV-YTV5NApZL8tut9g
Yeah I ended up going the same one, the only frustration was it doesnt come with M5 or M4 mandrels which would have been an obvious inclusion for such a compact tool. Who the hell uses rivnuts to hold an M10 bolt??
  • 4 weeks later...
So, I'm not sure if this actually classifies as tools but I'm really happy with these. The transition between my garage and driveway sucks. Without some boards, it scrapes the front lip even at stock ride height it ruined my OEM lip.
I have to get rid of the old board and cut a 4 x 6 on angle to replace those old boards.
  • Like 1
  • 9 months later...
Half moon obstruction ring spanner - Take that you pesky inaccessible fourth turbo nut you!
It's not quite perfect, still jams against the turbo front outlet, but better than nothing...
  • Like 7
I love these!
So good for header bolts/turbos
  • Like 1
Brilliant! Just ordered a set and I'll give them a go. Thank you!
  • Like 1
Me, used the M10's for attaching my Grundfos water pump to a welded up pedestal which in turn is SS dyna bolted to the pump shed floor, now I can pump water from my bottom tank to my top one....hehehe
  • Like 1
Also, what does everyone use to get to the water drain on the block, the one behind the turbo?
I tried a few different spanners and sockets and just cannot get a purchase on it, one thing I do know, when I finally get it out I an going to make one up with an extended head like 40-50mm hex bar and 50mm long as well.  Its a PITA to get to with anything decent.  Needs room for a breaker bar!!!
I cut a spanner in half then got a larger spanner on the back of it for leverage. Just enough room to turn it with the cut in half spanner after you break it loose.
  • Like 1
  • 9 months later...
Sort of; in that I have one in boxes on the shed floor.
When we moved out of the old place I've had to leave the hoist behind because
1/ I can't get 3 phase power here, and
2/ the shed roof is about 0.5m too short for the hoist I have.
So as this is kind of temporary (for a year or 3....), I grabbed one of these. Not unpacked or used yet, I haven't had a job that needed it so far but will have to change the sludge/oil in the bush basher soon enough and replace the water in the brake lines with brake fluid, both of which will give me a reason to give it a go.
Without having used it yet, thoughts from me are that it is very expensive (a full hoist is the same price or cheaper) and obviously won't let you stand under it but this is easy for clearance, has no install cost or requirements, is portable, and has no overhead clearance issues.
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
