After seeing the above, I got this one for $30 + postage.
http://www.ebay.com.au/itm/311514221310?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'll let you all know how it goes.
Also bought this about 12 months ago from Germany. Great for rivnuts in hard to get at places, does both nuts and threads.
Not sure if the address is the same business, I just found it and used it for the photo etc.
http://www.ebay.com.au/itm/Nutserts-Nutsert-Setting-Tool-M6-M12-Riv-Nut-Rivnuts-Rivet-Thinsheet-PNT210-/230986691661?hash=item35c7e1344d:m:mf7e5tV-YTV5NApZL8tut9g
Yeah I ended up going the same one, the only frustration was it doesnt come with M5 or M4 mandrels which would have been an obvious inclusion for such a compact tool. Who the hell uses rivnuts to hold an M10 bolt??
  • 4 weeks later...
So, I'm not sure if this actually classifies as tools but I'm really happy with these. The transition between my garage and driveway sucks. Without some boards, it scrapes the front lip even at stock ride height it ruined my OEM lip.
I have to get rid of the old board and cut a 4 x 6 on angle to replace those old boards.
  • Like 1
  • 9 months later...
Half moon obstruction ring spanner - Take that you pesky inaccessible fourth turbo nut you!
It's not quite perfect, still jams against the turbo front outlet, but better than nothing...
  • Like 7
I love these!
So good for header bolts/turbos
  • Like 1
Brilliant! Just ordered a set and I'll give them a go. Thank you!
  • Like 1
Me, used the M10's for attaching my Grundfos water pump to a welded up pedestal which in turn is SS dyna bolted to the pump shed floor, now I can pump water from my bottom tank to my top one....hehehe
  • Like 1
Also, what does everyone use to get to the water drain on the block, the one behind the turbo?
I tried a few different spanners and sockets and just cannot get a purchase on it, one thing I do know, when I finally get it out I an going to make one up with an extended head like 40-50mm hex bar and 50mm long as well.  Its a PITA to get to with anything decent.  Needs room for a breaker bar!!!
I cut a spanner in half then got a larger spanner on the back of it for leverage. Just enough room to turn it with the cut in half spanner after you break it loose.
  • Like 1
  • 9 months later...
Sort of; in that I have one in boxes on the shed floor.
When we moved out of the old place I've had to leave the hoist behind because
1/ I can't get 3 phase power here, and
2/ the shed roof is about 0.5m too short for the hoist I have.
So as this is kind of temporary (for a year or 3....), I grabbed one of these. Not unpacked or used yet, I haven't had a job that needed it so far but will have to change the sludge/oil in the bush basher soon enough and replace the water in the brake lines with brake fluid, both of which will give me a reason to give it a go.
Without having used it yet, thoughts from me are that it is very expensive (a full hoist is the same price or cheaper) and obviously won't let you stand under it but this is easy for clearance, has no install cost or requirements, is portable, and has no overhead clearance issues.
  • Like 1
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
