Maybe he decided not to build it after what happened to Paul's(ex-snowy's) car on the weekend....that was very nasty. Glad those guys are ok, they must have been rattled.
I heard Neil loves Cheryl like a daughter and may be afraid of driving her quickly.
It's all good guy's,,,Cheryl and I are alive and kicking.
Whilst I may have lost interest in this thread,,,trust me WE haven't stopped building her,,,far from it she runs again and drives.
Duncan may well be correct in saying she will have her 1st shakedown in December.
Cheers
Neil.
Dates and venues please, If its in Syney I would love to come and say hi and see her in the flesh during her first shake down.
I even have the tyre pressure guage you gave me, which sir both it and me are at your disposal.
Cheers
Neil.
I look forward to seeing all your hard work Neil!
Cool, I heard the other day that SAU-NSW is having a track day in December? Is that the SAU Track Day you are talking about?
I will be up for Xmas so would be great to finally get back on a NSW track...and just quickly. My car went ok at the Nats. Need some tyres and more talent as it wasnt overly quick :(
Speaking of old project cars.....
Ryan ive noticed you looking around for another R33??
Andrews car is sitting around and is up for sale.
Now has an r34 neo engine, resprayed in the same blue, new cooler kit, decent rims, interior is back in it with good seats etc.
Shoot me a pm if you are after a car still. It's sitting around with 4 other cars I'll never touch now the R34 is being built.
  • 4 weeks later...
She sure looks the part :worship:
I was talking to Brad at the "Legends Dinner" and he was saying that with the new paint the interior came up looking first class and from the pictures he was not kidding - well done Neil and Duncan.
Now all you need to do is have her completed for the Wakefield day in a few weeks for a shakedown run.
I'm ashamed I've only just stumbled across this thread Neil! Moving the cool car (read proper race cars with cages) threads from the Motorsport section was a mistake. I said that at the time.
Nice build mate! Your hectic engine bay looks as hard core as mine! lol
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
