That's great news Craig. I hope you work out the CAS issue soon & get back up to full power. No problems maxing out the standard injectors? I reckon they are highly under rated, especially if you've increased the flow via better pump or FPR.
even better new Leon......Problem is solved.....I now have CAS!
Car goes like stink again!......it's very neutral in balance........power is just right!
I bet thats a relief! Great work.
Are we allowed to ask what the problem was? :)
Mate, that is great news. Btw, that stink would be left from your last passenger. I recommend a steam clean.
It was fixed by cutting the top off a zip tie and using it as a shim on the CAS.........so in other words I had to change the angle of the CAS slightly. f**k I wish I had the money back that I had thrown at this problem. I think every expert that I know or Dad knows has either had a look at the car or tried to diagnose it. Alex and I found the problem because I decided to test my spare CAS's before biting the bullet and buying another brand new one and when changing them back and forth this time I found inconsistencies in the RPM missfire and startup....so I fiddled and applied pressure in different directions and it either killed it , cleared it or f#$ked up the idle.....at first I thought the plug was stuffed but it seems that when we had done the GB change the CAS location has changed ever so slightly.....I dont' know how either it does not make sense!
Funniest thing is one or 2 of the workshops decided to call me and Forums a waist of time and we don't know anything.
I have a small quote for them!
"IN YOU FACE MR MECHANIC!"
Craig Markland
I might just point this out to them those workshops as well!
Happy days to......onto the next part of the project!....ECU's again!
Craig Markland
So time to do a drag strip meet to put a time on all our mods... :)
I think SO!....I still need to get the new Box in, Change spark plugs and do an oil change first.
Plus fit new bitsph34r.gif.....wont be cracking a mid 12 second past as I don't have the E-Manage on anymore but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!
Edited by Jetwreck
.... but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!....running stock injectors.....on pump fuel
edited your post for more drama, lol
I drove another M35 last night that does 14.4's..........I know my car is a lot quicker than that so it should be very interesting....at 18-19PSI my AFR's are at 10.8 so it's still got more in it except the AFM is stopping it....needs to be clamped somehow!
Good to hear you got it sorted, bastard it was one of those seemingly intangible fixes (cable tie? Really??)
ECU's? I can help you out with that :)
Edited by iamhe77
Jaycar have fuel cut defeater kit that I used on my last 33. It was only $20 or so to build. It has a trim pot so you can turn the cut of voltage right down.
How do you add fuel to the map with the voltage clamped so low? It's not a set figure, it changes with revs/load compared to what the ecu is expecting.
I agree. If it does clamp the AFM signal to 3.9V, the ECU won't add enough fuel under highish load IMO. My car reaches 3.9V long before WOT. Nothing wrong with modifying the AFM voltage, but to run nice it needs to vary under all the conditions the ECU is looking at.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
