That's great news Craig. I hope you work out the CAS issue soon & get back up to full power. No problems maxing out the standard injectors? I reckon they are highly under rated, especially if you've increased the flow via better pump or FPR.
even better new Leon......Problem is solved.....I now have CAS!
Car goes like stink again!......it's very neutral in balance........power is just right!
I bet thats a relief! Great work.
Are we allowed to ask what the problem was? :)
Mate, that is great news. Btw, that stink would be left from your last passenger. I recommend a steam clean.
It was fixed by cutting the top off a zip tie and using it as a shim on the CAS.........so in other words I had to change the angle of the CAS slightly. f**k I wish I had the money back that I had thrown at this problem. I think every expert that I know or Dad knows has either had a look at the car or tried to diagnose it. Alex and I found the problem because I decided to test my spare CAS's before biting the bullet and buying another brand new one and when changing them back and forth this time I found inconsistencies in the RPM missfire and startup....so I fiddled and applied pressure in different directions and it either killed it , cleared it or f#$ked up the idle.....at first I thought the plug was stuffed but it seems that when we had done the GB change the CAS location has changed ever so slightly.....I dont' know how either it does not make sense!
Funniest thing is one or 2 of the workshops decided to call me and Forums a waist of time and we don't know anything.
I have a small quote for them!
"IN YOU FACE MR MECHANIC!"
Craig Markland
I might just point this out to them those workshops as well!
Happy days to......onto the next part of the project!....ECU's again!
Craig Markland
So time to do a drag strip meet to put a time on all our mods... :)
I think SO!....I still need to get the new Box in, Change spark plugs and do an oil change first.
Plus fit new bitsph34r.gif.....wont be cracking a mid 12 second past as I don't have the E-Manage on anymore but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!
Edited by Jetwreck
.... but I should get a low 13 second pass!....still not bad for a 2 tonne fat cow!....running stock injectors.....on pump fuel
edited your post for more drama, lol
I drove another M35 last night that does 14.4's..........I know my car is a lot quicker than that so it should be very interesting....at 18-19PSI my AFR's are at 10.8 so it's still got more in it except the AFM is stopping it....needs to be clamped somehow!
Good to hear you got it sorted, bastard it was one of those seemingly intangible fixes (cable tie? Really??)
ECU's? I can help you out with that :)
Edited by iamhe77
Jaycar have fuel cut defeater kit that I used on my last 33. It was only $20 or so to build. It has a trim pot so you can turn the cut of voltage right down.
How do you add fuel to the map with the voltage clamped so low? It's not a set figure, it changes with revs/load compared to what the ecu is expecting.
I agree. If it does clamp the AFM signal to 3.9V, the ECU won't add enough fuel under highish load IMO. My car reaches 3.9V long before WOT. Nothing wrong with modifying the AFM voltage, but to run nice it needs to vary under all the conditions the ECU is looking at.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
