I wish it was an media pc, it's just a windows 6.0 based head unit. Still trying to find a way to get Nissan data scan to load in it.
But yeah deffinately looks nice.
Mmmmmm let me see ........
1. FMIC
2. Removed passenger door lock
3. Relocated Auto Cooler
4. Dolphin bummper and grill
5. Masa front Fenders
6. Converted Navi to Standered Aircon
7. Front and Rear swaybars
8. 350z Front Rotors
9. Rs 260 spoiler(copy)
10. Subbox and Guage pod by member FGJOH
11. Rola roof rack
12. full 3" exhast
13. Niztune(to be installed)
I think thats it so far.............
Cheers
Darq
You know where I am if you want to lighten your wallet a bit more and get the conversion done. ha ha :whistling:
Hey Brad, i will PM you soon to do the conversion
my wallet needs to recover first
Got my new sub box from Fgjoh in, very happy with it. It takes up a lot less space than the giant box i had before, and i think its a bit lighter as well.
Also just realised how dirty the boot is, after looking at that photo pinch.gif
Edited by 180fan
Good to hear your happy with it
I think the box could sit in a bit more though
best idea would be to loosen the bolt behind the cargo blind hook as the metal tag should not be visible( you may need to bend it a little to suit the shape of the plastic
Let me know how you go if you need pointers over the phone gimme a buzz on 0423487790
Cheers,
Pete
i did some weight reduction left half my car on 4 speed humps on the weekend LOL............ havent jacked it up to check the damage but i think its not to bad, fingers crossed
Got a new set of KU31s today, from Tempe. $190 a tyre fitted, was pretty happy with the service. Quick turnaround, and they were careful with my wheels.
Was out in some amazingly heavy rain yesterday, first time the Stagea has ever aquaplaned even though the tyres weren't quite on the wear markers. Todays torrential rain; rock solid, just like always.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
