Have you done brake lines as we'll? Very interested in doing this
haven't done the brake line. Tried to look for it locally but could find it unless custom made. But so far changing the fresh brake fluid and cusco brake stopper really helps.
Last couple of weeks installed new upper rear ajustsble control arms, new bushes for rear sway bar , new front sway bar bushes, and a new battery on Thursday, got one of those new green battery's from battery world
Going to tackle cleaning my coils and putting electro paste on them to see if I can resolve my miss around the 5k rpm mark
keep us posted on the electro paste results, as far as i know in bad situations the spark can leak and ground into the head area
Headgasket lifted slightly in two spots so engine is out on the yellow pig. While out I will take advantage and replace a few hoses and bibs and bobs while on a stand.
The good news is that the bores look pristine with minimal carbon build up. Not as pretty as an ethanol run engine but not too bad given the number of kms, number of dyno runs and the abuse by Ms Wolv (just daily driving in Sydney) for all those years. While it is out we will refresh with OEM rings and ACL race bearings.
The head is being pressure tested before a complete head service and we can tighten up the valve clearances a whisker to get rid of the slight intermittent tick that has been there since the poncams were installed.
Picked up the stagea today from the panel shop after getting rear ended a week ago. Very happy with the work they done, plus now I am de-badged
Are there any pin holes under the badges other then the Nissan? Id like to remove the AXIS & Autech bagde if possible.
No there isn't, But there is another issue just as big really. From factory they put the badges on while the pain is still soft. So if you remove the badges with out sanding back and respraying it, you will have raised edges around where the badges used to be.
Really the best way to go is to arrange to be rear ended like Josh has done & have your car debadged when it is being repaired.
When I did mine that way a few years back I was given the badges on a cool template to allow me to stick in exactly the right place should I ever get the urge to rebadge.
BTW Josh, I'm no photographer but the potato you used to take that picture of your car needs its lens cleaned, or a steadier hand or something. :)
  • Like 3
Lol yeah there isnt much light in my carpark. Plus I couldn't be bothered re taking the picture
Written off due to to expensive to repair
Buy it back, and repair; an uneconomic repair write off isn't a statutory write off.
Stupid insurance companies...
Is this the point at which insurance companies become (even more) hypocritical? Surely they couldn't ask much for it at all otherwise they would have spent almost up to the insured value repairing it. I had an offset head-on way back in 1992 (man I sound old now) in a car insured for $8K and the insurers repaired it and gave it back, yet the damage must have been very close to $8K.
IF he wants it back of course.
I had the option of buying my Stagea back for $5k which I declined then watched it sell for under $2k at pickles. Bargain.
Could have fixed it but wanted the PM
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
