Cut out the front bumper and made a stainless steel bracket for the number plate that bolts in the factory position. Also rested on the eylids to see how they look before i get them painted pearl white.
  • Like 2
Noticed a knock in the front end since i installed the superpro 33mm solid front sway bar. Inspected it today and noticed a gap of 6mm (3mm each side) between the fixed rib and the support bush. So i made up 2 dense rubber spacers to fill the gap and stop the knocking. While i was at it i regreased the rear whiteline sway bar bushes as there was excessive creaking from the rear end. Another day another thing fixed. Next will be the passenger side inner driveshaft boot.
This weekend efforts on the wagon
1. Fitted the front half of my Alcon brake upgrade.
2. Drove it to WSID and ran a 12.2 (a PB).
3. Split the heater core on the way home and turned my girlfriends shoes a lovely shade of glycol green.
  • Like 2
Whilst vaccuming out the rear seat of the Stag over the weekend I was shocked to discover that under all the wrappers, leaves, stones, nuts, random bits of plastic, crayons and multitude of other crap that had built up over the past couple of years of being the famliy hauler...there is actually carpet back there. Who woulda thunk it. Somehow, it's still beige, and it's remarkably clean.
  • Like 1
After waiting for a VSS from Nissan for 3 weeks this beast is back on the road. And it was nice to see the previous owner change all the fluids except the transfer case in 18 years. It was very brown to say the least. Felt good to drive it again.
Edited by CaSilvia
1. Paddle shifter from V35 GT-8. Took of the leather wrap underneath is aluminium, I sanded it and polished. I can post a wiring diagram for anyone wants to do it.
2. Strutbar from Aliexpress.
3. Clock from a G35 through Ebay.
  • Like 1
That looks way better then the after market setup. And price looks possibly better. How is the feel?
And yes show us your wiring diagram :)
No. That one on Ebay is for a later model V36-37, and its hard work to modify. V35 GT-8 look like this and its a direct fit. Just remove the steering wheel and line up the holes. You will also need the top and bottom steering shroud if you want to return your car back to way it was.
  • Like 1
Any noticeable improvement over stock for the brace? Also price on the g35 strut brace?
Have a look at the front suspension, notice the strut isn't actually a part of the front end geometry or hub like the 33/34 skyline, it just provides downforce through the lower bush. Hence why the strutbrace makes no difference.
If you want to tighten the front end you need to brace the compression arm as Nissan did with the series 2 V35's (Dale's brace or OX motorsport), and use the Superpro poly compression bush.
  • Like 1
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
