They seem to be really good so far!
They're from Pro Rack
S-Wing Flush 950
Part Number: S5
Fitting Kit
Part Number: K528
I got them through roof rack superstore.
what did they set you back mate?
$350 fitted.
I didn't actually look at how much you could get them online, because I do a fair bit of work for the roof rack place I got them from. I assumed they at least kind of looked after me.
My leather seats arrived!! Now to fit them. I thought they might be plug and play with my RS Four S, but I was wrong. Has anyone put leather seats into a Stagea that didn't originally have them?
  • Like 1
Yes, and they were plug and play. But that was S1, do S2 have something extra like seat heaters? If so you need switches if they are not on the seat, and considering the power they could draw I'd probably run separate wiring too. Or you could just leave them unplugged and worry about it closer to winter...
Leather seats are installed!
First attempt: I was using the same power supply as one of my amps. Went well until I tried to start the car, and I killed a few Eng Cont fuses in the engine bay. Try again.
Second attempt: I ran the positive from the 12V cigarette output to the seats and the car started like a boss.
post-51740-14474128399648_thumb.jpgpost-51740-14474128491649_thumb.jpgpost-51740-14474128595224_thumb.jpg
So thank you to everyone who gave me some ideas on how to do this. Now to clean up the old RS4S seats and sell them.
  • Like 1
Riding this pile of monstrosity from the Stagea.
Utter disgusting install. Not even the bin is worthy of this crud.
wow, surely that was not all part of the install for the hu ?
finally my rear wing fly to Aus today.
fitting easily, gain 100hp :nyaanyaa::nyaanyaa:
looks great ! think you accidentally a 0 there ;)
This looks exactly like the pile of shit i pulled out of mine. There was over 15kg of old wiring that was not connected to anything at either end!
Got to take a look at my M35 tonight.
Something very cool about being under the hoist looking at the manual box in place. It looks kinda bare now with all the AWD bits and auto missing :P
New radiator on, 6pd box in place, braided lines and wiring to be sorted tomorrow or late tonight i assume. All things pointing towards trying to turn the key hopefully this week. Tail shaft however probably won't be in till early / mid next week which is fine as other jobs are still needed (centre console / handbrake etc)
  • Like 4
Pics not loading...
  • Like 5
This week I drove the S1, RS4 to Sydney and back. 1100k all up. I have had it for nearly ten years.And has 198 on the clock. Looked after but not pampered. A proper work horse.
It is really the first long trip I have done in it. Never missed a beat the whole trip. Was driven hard and gave 520 per tank. And was so comfortable even on the 11 hour o/nite trip down.
  • Like 1
Not so much a what have I done but a what I will do when the wife and kids give me 5 minutes of peace!
Next on the list will be coilovers, looking at MCA, Blitz ZZ-R and BC BR RS.
Anyone running the Blitz or MCA or anything else they are happy with?
  • Like 2
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
