Just drove the Stagea all of 30 metres, if that!  Reversed it out of the garage and driveway, turned it around at the T-intersection on the corner of where my house is, then reversed it back in so it can be tucked up tight against the wall and take up less room in the carport.
A light clutch suddenly feels a little bit heavier when you haven't driven a manual for ages...
Gonna have to figure out why the radio stopped working, hopefully it's just a fuse and easy to sort out so I can use it more when the weather warms up a bit.   Car loves the cold, I don't.
Good thing is that it's got a fresh pink slip, thanks to the grumpy old man, LOL.  He's driven it more than I have!
After 3 years, 1 month and two weeks of owning my Stagea, I think I've finally found the little directional toggle switch that is used to control the cursor on the TV. My wife found it lodged under the driver's set while cleaning out the car, the TV itself doesn't actually pop up (stillhaven't got round to sorting it) but it's nice to collect the full set of buttons.
Can someone with a PM/PNM35 please tell me, does the controller switch have two Japanese characters on it? Google Translate tells me it says "decision" but I'm guessing it means "select". Otherwise it's a button for something else and I have no idea what.
Did an oil and filter change using an Aeroflow filter so I'll see how that goes.
This one: https://www.aeroflowperformance.com/oil-systems-accessories/oil-filters/spin-on/af2296-1010
Also put in a Whiteline diff bush kit (thanks Daleo) and changed the diff oil.
Diff bushes came out pretty easy with a hammer, washer and some pipe.
579efe3a7ef54_2016-07-3016.01.22.thumb.j
Used this setup to try and remove the subframe bush. You can see the juice from the leaky bush. :blush:
579efeb6d9b15_2016-07-3015.57.55.thumb.j579efedd521a6_2016-07-3015.59.36.thumb.j
I got it out halfway before snapping the bolt and a length of all-thread. It was in there tight! I'd suggest using a head bolt or something high tensile. I ended up pushing out the rubber centre and then cutting out the shell with a hacksaw. All went back in ok and feels all good on the road.
Replaced my center AC vents/trim with a fresh one from Yahoo auctions, wasn't necessary, but there were some small nicks and scratches on it when I got the car
also bidding on a Carbing Okuyama rear tower strut bar and a Do-Luck rear crossbar
Been a big weekend with installing bits on the M35.
- swapped over my r34gtt front pads (nismo)
- installed and rewired side mirrors
- installed moshimoto alloy radiator
- installed scotty cooling mod
- installed nismo thermostat
- replaced lower radiator hose
- replaced driverside wiper.
Future mods for secured parts
- gearbox swap (shift kitted)
- walboro 255 fuel pump
- full 3 inch exhaust (scotty front pipe, fujitbuso legalis catback)
- plenum spacer
- Adaptronic with cable throttle set up
- 1000cc injectors
- replace rear door
- daleo intake
- tune.
988373132793a1243ab11809aa5410ab.jpgffd52ec06e7ddd2ad6bb94aa97099360.jpg028a00561140af1e8c249826271f2fba.jpg74caab01624b7fbba6ff6ce5cf6edea7.jpg95aa30f0f99596beb942aec66954ec02.jpgbe05b0b4c2f8f9e8788f2db7e402827e.jpg899e60a3e9b78b1cd9f41cf245102fdb.jpg8b2699ac28814664203404ad8204b4f4.jpg
  • Like 3
5 hours ago, TukeH said:
a small lights project. for a long time wanted to do that and it was not difficult
later the smoke Lamin-X.
ps. neighbors volvo background
Those ramps are awesome!
  • Like 2
 finishing is still missing
all garbage timber which found the plot. otherwise would have gone to the sauna chamber :)
sometimes need to make higher
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
