hey quick question...
How much does this thing weigh now?
Will let you know in a few weeks...
Its not going to be overly light as it still retains factory power windows and doors etc... Adding the accusump and cage would have weighed it down a bit too... Will be interesting to see!
Looks nuts dude well done!
Facebook is blocked at work but will check out the smash repair place when it's home time :rofl2:
Thanks mate! Pretty happy with it all...
Vacy Smash Repairs have done an epic job and i couldnt have done it without them...
over 9000.
  • 3 weeks later...
Some more pics being uploaded to FB over the coming weeks. While the car was clean out of the booth we decided it was a good time to get stuck into it and take some nice clean pics...
https://www.facebook.com/Woottenracing/photos/a.819477888122136.1073741829.817653311637927/887547627981828/?type=1&theater
Thanks to Vacy Smash Repairs for the amazing paint work and also to Hosking Industries for the photo shoot! Ill update details in here in the near future as it will be featuring in a couple of magazines.
  • Like 1
Haven't sent his build thread for a while, am amazed how it looks now
Good to see someone repping the GTT on the track :thumbsup:
Thanks mate, been busy at work and on the car so havent really updated anything for a while... Slowly getting there though :)
Sneak preview of the photoshoot with Hosking Industries -
https://www.facebook.com/HoskingIndustries/photos/a.305186982862282.66384.151361221578193/894152483965726/?type=3&theater
Will post proper images and updates once they are all done and released.
  • Like 2
Looks f**king mean!!
Sure does ;)
Very keen for the pics!
Sorry if i've missed it, are you competing in wtac this year?
Nope mate, i knew it was an unrealistic goal a few months ago! I could still technically make it but going to a big event untested is just a recipe for drama...
The car will do more club level and Super Sprint style events until i learn to steer it haha
Looking awesome.. :wink: any plans for future motor or keep replacing with stock neo's if it ever lets go that is.. :biggrin:
Lol stock FTW :P
I have discussed a turbo change with Forced Performance, so eventually ill have a new surprise :P
Fair enough mate, i was gonna say i'd love to come say gday and check out the car in person!
Next year maybe ;)
Come down on the Sunday to SMSP North as it and I will be there mate ;)
  • Like 1
  • 4 weeks later...
Hey Mat I just saw a photo of your re-incarnated 34 in the R34s...please thread, looks awesome!
The custom undertray extension was made too, this stays fixed to the car when the front end is removed -
11270139_1414327222230544_91766185_n_zps
Sorry to jump in but a quick question about the undertray, have you got a photo from underneath with the full front end in place?
Are you running an undertray/diffuser out the back at all?
I'm keen to DIY a flatter undertray for my GTT at some stage and looking for some pointers :)
Hi Mate,
No not at this stage, will develop it as time goes on but at this stage its just what you see in the image above.
  • Like 1
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
