That's awesome!
Bit of an update.
Got a new gearbox in today. Old one didn't have synchros in 3rd or 4th any more..
Cage is now painted. What a pain in the arse job!!! Don't want to do that again!
Another full day at the factory tomorrow for more prep for Winton next monday.
Had a big successful weekend.
Cage is now painted. Like I said. Don't wanna do that again!
Interior is back together.
Replacement gearbox
The car is back together and pretty much ready for Winton.
With help from my mate Johnny we had the alignment finished at 1am last night! We set up camber, caster and toe. I'm back working in Swan hill for the week so had to get as much done as possible before I left.
Before Winton I still need to finish wiring in my new AFR guage, change the oil, fix my camera mount to my new cage and I'm ready to go!
post-10715-0-78771700-1338896739_thumb.jpgpost-10715-0-15884400-1338896749_thumb.jpgpost-10715-0-50821600-1338896789_thumb.jpgpost-10715-0-56271900-1338896804_thumb.jpg
Next up is corner weighing! Will be interesting to see how much it weighs!
Replacement gearbox
Hah it's been ages since I've seen someone do the string alignment! I'd be curious to learn how you do it!
Yeah bris. At least it's only the battery!
Jack. The string alignment is basically an even rectangle around the car and measurements taken from there. Requires lots of patience. Camber and Caster is done with a made up tool. Courtesy of Femino (ACE Workshop) :)
Thanks Bris!
Massive day today at Winton. Had dramas all morning but I think I can put it down to me starting to look at the guages a lot more. Oil pressure dropped from like 6-8 bar to 2 bar sharply under brakes and picked up almost immediately after every time. This was very off putting and didn't seem right. I'm thinking that is always done it and I'm just taking more notice now that I'm stressing everything more.
In an attempt to try and stop the surge we put more oil in and it just blew into the catch can and put oil all over the engine bay. This might be just the icing on the cake coz I can't remember the last time I emptied the catch can... :whistling:
After this had settled down and I was trusting the setup more I was starting to lean on it and wow... the E85 pulls like a frieken train!!!!!!!!!!!!! It's unbelievable! 295's offered lots of grip even though the are quite 2nd hand. New coil overs were very nice and probably a little more settled than the old set. Not sure why but didn't get any turn in over steer like I did with the RE's.
Footage will come but the final time for today was 1:31.29 that's 2.4 secs faster than last year at SAU nats in October and now the fastest skyline around Winton on Semi's. Not sure how long it can stay like that for though haha. Thanks to all that helped out at the track or on the phone.
Disagree...If you do plumb it back to the sump then at least put a valve on it. You want to be able to observe how much blow by you are getting and if the oil is draining back then you dont have the opportunity to monitor. Myabe with a valve you can simply open the valve and drain it back at the end of a session. Also, catch cans are open to atmosphere generally and fill up with condensation and rubbish in a rarely driven track car that is only being turned over to move around factory or put on trailers etc.
Great stuff Russman.
So what rims and offset you have on the rear end of the car? Are you running GTR rear guards... have they been rolled?
Sorry I probably missed it earlier in the thread, thanks.
Thanks Bris!
Awsome work!
I had the same problem with my setup....Under hard braking....pressures dropped to about 20psi.... Although my motor didnt pop.. i am now going dry sump.
I ran a Tomei Oil pump with a Hi Octane Sump.... there was always enough oil in this but alot of workshops could not help with my problem. I was talking to a few people
and got some tips off the Gibsons GTR sump design with pickup points/baffling etc.... BUT one thing that did help was a Morroso accumulater (i actually have one spare now :P)
it stored ~1litre of oil under pressure and would expel when pressures dropped.... not really designed for this purpose of pressure drops under braking but helped my circumstances..... I was contemplating to do a external pickup but was too much mucking about on a 4WD that was already running. Also driving style helps... if you can try to settle the car more going into
these corners!!!... hope this helps
:cheers:
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
