So it's been a while since I've posted an update. That's because I've been so flat out! What a hectic month!
I'll go through the lead up first and then talk about WTAC and how massive the weekend was and how my mates/team helped me achieve a great result!
So PI as you may have read in Kory's write up didn't go to plan.
A faulty injector plug on cylinder 5 caused this...
The day after we had it pulled down and everything ready to go on Campbell's motor that he donated so I could get to WTAC.
We also noticed that the ASI ebay radiator wasn't handling the pressures of racing. Kinda a bit bent...
So we got a racepace spec radiator and so far it's great. temps have never been so low. It's crazy effective.
The lexan glass is now in.
Johnny and matt ripped into the doors and all up took out 15kg, that's just steel! Glass on top of that!
All this weight reduction got the car down to 1249kg with no driver and no fuel. Not bad for a full caged car!
So the mad engineers bent me up a Gurney flap for the rear wing.
Matt separating the fibreglass headlight from the mould. This by the way was tuesday night around 11pm. We left for WTAC on wednesday morning 5:30!
Front splitter painted last minute for WTAC
I think I'll leave it there for now. The WTAC story is a big one so I'll post that up at a later date.
That ASI radiator photo is exactly what flea-bay lovers need to see.
Good for a street car, not suitable for trackwork, reflected in the price.
I agree 90%
For most guys they are fine
But on a car like Russ'
Well the pictures speak 1000 words
Back on topic, how did you find the gurney flap Russ? Noticeable difference?
Love the build, though I'd be remaking the gurney lap if I were you. The height of the flap looks too large for the chord length of that wing. You'll be getting an inefficient level of drag associated with the extra down force the flap is creating. You should be looking at a gurney flap of around 5 -10mm in height.
Rad was fine for 1 year of track work. Got gradually worse. Seen them on other track cars so thought they'd hold up. No problems with cooling though, just construction. Looks like its deformed from high pressure. No head gasket issues, that's what we first thought haha.
Gurney flap and change of angle was very noticeable at turn 1 EC. The car felt way more stable and I think it may have had something to do with the final session being 1 sec quicker! The boot required re-packing after every session. By the end of saturday we had about 4-5 washers spacing it up! Need to do something more permanent now. Proper boot lid re-enforcement.
The gurney was actually mounted underneath the wing to begin with but spoke to an aero guy at WTAC and he recommended putting it above the wing so it sits higher as a result.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
