That awkward moment when Lady Gaga stops looking like a tranny and starts looking like a really hot woman... I'm not sure how I should be feeling... But I'm sure that this isn't it...
beau temps aujourd'hui.
nice night here/tonight
vraiment?
Et bien il pleut enfin chez nous. C'est merveilleux car on n'en n'a vraiment besoin ici
really? and a nice evening for cheezles. it's a marvellous car with really comfy seats
