Meanwhile in America
Dodge Challenger Hellcat
527kw, 880nm
From factory will run the quarter in less than 11 seconds
$60k USD
So glad there's a nation out there continuing to produce something like this, while the rest of the world pussies out of fking the environment
and it has a hole in one of the driving lights to turn it into a cold air intake...'Murica yeah
Having lived in 'Murica, they sure do have cheap cars.
Also, seeing things like the challenger make me say 'MURRICCAAAAA but not jokingly.
They kind of build the things that HSV/FPV should have been building for many, many years.
Bloke at work had a 2006 Alfa GT, it was so horribly unreliable...
He was trying to sell it for over a year with hardly any bites... 2 months ago some drunk kids (??) ran over the top it it (and a few other cars in the street) and it was written off. Great success!
Bastard sat in my backyard for 6 months while he was overseas, there's still a mark on the lawn :P
and yet another.
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-2764343&Cr=8
ok so car described as a wagon. you then write in comments that is a wagon to clarify.
yet pictures are of a sedan.
god dam scammers
New 2015 Mustang GT350 has 500HP and is designed as a track car. Basically the Boss 302 replacement.
New XR8 also has a reverse cowl out of the factory. MmmHmm.
yeah and brembos on the xr8! looks alright from what I've heard / read
happy with the GS who knows might upgrade to the mustang when it comes out here if they aren't crazy expensive.. although nek minit mustang will be the next gt86 where everyone has one.. at least it'll have some power :P
Edited by UNR33L
  • Like 1
although nek minit mustang with be the next gt86 where everyone has one.. at least it'll have some power :P
Dad bought a Boss 302 for this reason. Since there will be no more Falcon's, Mustang will be the new performance car and everyone will have one.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
