thanks for the tip.
says new update requires iOS7. time for new phone
Why don't you just install iOS7? haha
Otherwise, if you're staying on iPhone the next one will be released in a few weeks (apparently) so it's best to hold off
have her buy you $20 in drinks slam her all night.
bourbon & coke + lemon, lime bitters = $20.
i'd rather a kebab and a coke tbh. or being pommy, might take you to a good curry joint.
my phone is in struggletown. buttons broken, unresponsive etc.
i stopped updating it for a number of reasons. time to move on. might put work phone on iOS7
SOB
I kept 2.5 Kuwait $ from last trip just in case ever went back as the visa on arrival is 2 KD
just got told going back.
check site, they put up the visa cost to 3KD.
have to hit up the money changer for 50 cents.
(as they don't accept note bigger than one KD so ATM no use.)
SOB
Good thing you find out before going there?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
