thanks for the tip.
says new update requires iOS7. time for new phone
Why don't you just install iOS7? haha
Otherwise, if you're staying on iPhone the next one will be released in a few weeks (apparently) so it's best to hold off
have her buy you $20 in drinks slam her all night.
bourbon & coke + lemon, lime bitters = $20.
i'd rather a kebab and a coke tbh. or being pommy, might take you to a good curry joint.
my phone is in struggletown. buttons broken, unresponsive etc.
i stopped updating it for a number of reasons. time to move on. might put work phone on iOS7
SOB
I kept 2.5 Kuwait $ from last trip just in case ever went back as the visa on arrival is 2 KD
just got told going back.
check site, they put up the visa cost to 3KD.
have to hit up the money changer for 50 cents.
(as they don't accept note bigger than one KD so ATM no use.)
SOB
Good thing you find out before going there?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
