thanks for the tip.
says new update requires iOS7. time for new phone
Why don't you just install iOS7? haha
Otherwise, if you're staying on iPhone the next one will be released in a few weeks (apparently) so it's best to hold off
have her buy you $20 in drinks slam her all night.
bourbon & coke + lemon, lime bitters = $20.
i'd rather a kebab and a coke tbh. or being pommy, might take you to a good curry joint.
my phone is in struggletown. buttons broken, unresponsive etc.
i stopped updating it for a number of reasons. time to move on. might put work phone on iOS7
SOB
I kept 2.5 Kuwait $ from last trip just in case ever went back as the visa on arrival is 2 KD
just got told going back.
check site, they put up the visa cost to 3KD.
have to hit up the money changer for 50 cents.
(as they don't accept note bigger than one KD so ATM no use.)
SOB
Good thing you find out before going there?
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
