Well if it helps mine was flashing non stop auto elec tried looked everywhere turned out autobarn slightly snipped wire in passenger footwell that was causing the light on dash to flash so they fixed that and problem forever solved
That's the thing, I'm pretty certain something is cut or unplugged or what have you. Happened since an engine swap :P. Was looking for info as to where everything should be, the only thing I have to go on is the pinout diagram on the SRS ECU behind the handbrake, which is I guess what I'll have to do
Srs plugs are yellow, I'm betting you're missing an srs module or something
It was working prior to the engine/transmission swap, would be odd for an entire module to just go missing.. but was trying to find info on where it would be...
You still have the stock ecu so can't my consult 3 plug into it to read stuff Greg?
Probably!
The epic autoelec did try and read this, but it didn't actually throw an error, which according to the workshop manual says voltage to the system is under 9v
Which could easily mean a wire is snipped........somewhere
Spoke to import monster about sourcing some brand new wheels and said they can get direct from wholesale. Didnt think you could wholesale wheels... Especially with so many size variations and styles. Its not like theyre shoes or something
lol ^
Never buy a car at w'bee nissan biggest bunch of flogs I've dealt with in my life.
They owe me $8 been chasing it for 2 months! How places remain in business when they offer such horrible customer service is mind boggling
Side note - has nothing to do with the amount just the principal of the matter
That sounds exactly like shoes...
shoes have sizes + colours, plus are fairly small boxes.
wheels are large, come in a combination of sizes (#'diameter x #'widths x #'PCD x #'offsets = a f**kload). how can you have wholesale if most of it is made to order?
I inquired because wheel manufacturer brochure says wheel cost 90,000yen for example, but can buy brand new on yahoo auctions (in any offset you want) for 48,000yen.
fkwit kids have realised that they can do what they want without getting a punishment which is equivalent to the crime...
I say, do an adult crime, get punished like an adult.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
