I know of a surveyor who went to wa straight of out uni. Sitting on around $80k. To her and her peers it's solid dough, to me it's 3 years wasted on top of the 4-5 years total of uni-masters. But at least you have a life at uni. Who wants a house in WA anyway?
So my work car now is a corolla, 2010 or something auto with a whopping bb 337,000kms on ...
And I must give it credit..it gets whored out and cops a beating, smashed around bumpy gravel tracks in the dark and its still solid....and it goes reasonably well too...much better than that manual Hyundai gets I had that was also 1.6lt but always felt like it needed more power
Downpoints...cupholder is broken, tho still holds a takeaway latté...needs new shocks
85,000km/year... dayam... I'm always more impressed when small cars last a long time, instead of the usual 400,000+ falcon
So it holds a Latte for a while... and then throws it at you with disgust whenever you hit a bump.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
