Nab is great. Work/life balance is amazing and the culture is very strong. Most people stuck around for a LONG time. We do pay less than the other 3 however generally have higher bonuses
(Which kinda backfires when you we buy failing banks in England and have to provision hundreds of millions then cut bonuses lol)
interesting.
I swore that when I left my current place I would move to a much much smaller company.
would not be IT as per desktop support stuff, moved away from that years ago.
this is a Security Role...
LOL no shit.
I didn't think they were flying you around the world to personally switch it off and then switch it back on again.
  • Like 1
LOL no shit.
actually I have pretty well done this....
well more be onsite whilst they did in case it did not come back up.
  • Like 1
that GTR sounds tuff
also guy in the VL wagon can steer. (considering the way the car is handling)
also dat rotor.
I invited him to the next Sandown day when he asked about it... gave him all the details on how to enter... no dice, would rather just sit on the internet and circle jerk about power figures
I know several people who have worked IT in NAB.
None of them stayed very long, everyone had massive, massive complaints about the structure there and the culture.
Note: This was in level 2-3 support roles. May or may not apply. Enough that I stayed well clear of the place.
In other news, went for a drive with my cracked tank because f**kit YOLO
(will check part numbers at Kudos re R33 and R34 tanks btw)
Split a coolant line
Had to stop about 15 times on the way home to fill up radiator
good times
  • Like 1
Sadly, Mcguyver came in the way of using old liquor bottles to fill up radiator.
Did lol at filling radiator with water coming out of Absolut vodka bottles... x5
Figured that would be Mcguyvery enough. Did get home!
when I split mine.
turned radiator cap one notch back so it realease a bit of pressure and not pump fluid everywhere
made it the 30 km home with only a loss of 500ml,,,
then replaced radiator, hoses, water pump and fan belts, never had a cooling issue again.
when I split mine.
That up there is an excellent idea.
Not in your case Greg, your pistons would probably exit via the exhaust tip. :P
  • Like 1
leeroy played some official race on iracing.. fark me annoying I just kept getting taken out then finished like 11th, nek minit my license goes down a few points because of all the incidents
then I race a 'popular race' not official, come 2nd and it doesn't count toward anything! raging
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
