I'll try to minimise on the ramble as much as possible.
I've notice these days on the markets there are a few options for twin scroll turbos for the humble RBs, but what I've notice is that the manifold choices available which sometimes confuses me on what the best possible setup is.
1. Manifolds that group Cylinders 123 and 456 together and have 1x external wastegate mount (not true twin scroll manifold as the exhaust pressure clashes at the collector -> gate mount)
2. Manifolds that group Cylinders 123 and 456 together and have 2x external wastegate mount (true twin scroll manifold, separate gas flow for grouped cylinders, mimising exhaust back pressure )
3. Manifolds that group Cylinders 123 and 456 and have no gate mount, makes use of the turbo's waste gate
Imagine the previous with external waste gates blocked off & a turbo like the below from a WRX:
Point 1, the purpose of a twin scroll manifold is to purely group the exhaust gases so that there is less exhaust back pressure & chances of other post fired cylinders sucking back the exhaust gases. If the collector merges the 2x groups, is there really a point in that manifold might as well just have a 6 to 1 collector instead of a split collector
Point 2: Ideally the right setup, but the most expensive and the most complicated (usually A/C lines are removed etc.)
Point 3: The V Band clamp on the housing would eliminate the need to run 2x gates and make the manifold more simple, I've seen weldies here but not the off the shelf kit as so.
Now, I like the ideal of Point 3, but I have yet to see an off the shelf turbo with such housing with a V Band clamp on it, I have see people weld them on, but that's another cost to add. i prefer off the shelf kits because of cost and aesthetics. With Point 3 what are the Cons to it? At the moment I only see Pros to it because:
  1. No need cut and shut turbo exhause housing
  2. True twin scroll, exhaust gases from cylinder 123 and 456 ever only meet in the exhaust housing
  3. Looks more "stock" (I'm ready to cop ccriticism on this)
  4. Minimises pipe work, ultimately leads to a nicer setup.
Ideally, what setup would yield the best response and torque?
Well, maybe you're a little off base. It's not about "back pressure". Grouping the pulses together is literally about grouping the pulses together. There is an even spread of 3 pulses in each group, separated by the same numbers of degrees of rotation. This gives a slightly better response by nozzling each group separately onto the turbine.
These pulses are not just static pressure. They are also a burst of gas travelling at rather high speed. There is a lot of velocity pressure involved. So realistically, for any given twin scroll manifold that had just the one wastegate offtake, as long as the wastegate offtake from each half of the manifold was not directly connected to each other (ie ideally if there were separate short pipes from each half that merged together where the wastegate mounts) then the pulses are still going to travel direct to the turbine as required.
And that is exactly what your top photo shows, and that is perfectly fine with me.
You have to remember that there are two operating modes here. 1) The engine is not on boost yet. The wastegate(s) is(are) closed. All the flow is twoards the turbine. The pulses will travel past the wastegate offtakes. Maybe there'll be some leakage of each pulse via the wastegate connection to the other group of three, but it won't be heaps. 2) The engine is on boost. When on boost the exhaust manifold pressure is pretty high and some of the gas is always making the turn to flow towards the wastegate. The exhaust pulses now have a lot more velocity energy and will still travel towards the turbine, and a portion of gas will flow to the wastegate. That flow towards the wastegate will have its own velocity pressure, and as the direction of that flow is towards the wastegate itself, there will be only a small amount of "leakage" back towards the other group of 3 from each pulse.
I simply wouldn't worry about it. I'm sure that a true double wastegate design is the best overall, but the margin is probably reasonably small.
Weld wastegate pipe onto turbine housing and have no gate pipe off the manifold. Better response, more power, end story
That was what I was thinking, as per Point 3. That 3076 for a WRX has a V Band clamp on the exhaust housing for an external gate. Nice and clean setup, no need to cut and shut a $2k turbo. In saying that, I have yet to see one adapted to a RB.
My last two turbo setups had the gate off the turbine housing, you can make it look great if you have a good fab/welder guy.
heya NYTSKY, sorry I meant to say off the shelf turbo for a RB motor with a V Band clamp as below. I have seen a several setups where wastegates mounts are welded to the turbine housing. I have yet to see anything below used on a RB motor.
I have my own thoughts on how to mount a wastegate. Will be poutting it to test soon and hopefully will work waaay much better then the current 6boost-Turbosmart arrangment
Lets see a MSPaing Jig! Share share!
That housing is used on a specific motor/turbo arrangement. I highly doubt one would be made just for an aftermarket RB application.
Especially when one can be fabricated so easily.
Im having two 38mm gates on my next manifold, single entry Vband. Was going to be T4 divided but couldnt get a housing to suit my turbo in time.
Anyone put two gates on a single entry manifold before?
I have an ATP 0.82 T3 TS but they also make T4 flanged versions with V-band outlets as stated above.
I bought the turbo through streettotrack but procharge can also supply the housings if you are looking for an alternate.
So how would you go about welding a wastegate onto a twin scrolled turbocharger like the borg warner s366. Would you then weld something like 2 x 38mm tial gates on each side of the divided housing?
I would like to see pictures of these setups. We dont see much of these setups here in the states.
I'll have pics up soon of a twin scroll manifold with twin 38 mm gates plumbed into a 4 inch exhaust.. Running a BWs300sx 83/75 on a 26
Its will look awesome but is a real head ache to make happen
Edited by GTR_JOEY
I respectfully disagree, my first kit was from ETM and had the Tial 44mm mounted from the housing (GT3582R) The thing never controlled boost past 4500rpm. Fail
I am quite happy with my custom steam pipe manifold running a single 60mm gate with a Precision Billet 6262 and it holds 1.3 bar solid all day every day :thanks:
Edited by Weapon
Not sure why. We have them control boost perfectly on everything from GT3076's running 1 or even 2 bar up to GT4508's running 3.5 bar. All on 2.5 and 3L 6 cyl engines
It's good that you got your setup working properly but I don't know that the fact the gate pipe was welded off the housing was the cause.
  • 5 months later...
Thought I would boot this thread in the backside with a link to a photo of someones good work: http://www.eagletalon.net/pictures/index.php/2006/Red-Car/wastegate/IMG_1002
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
