Here's the setup I am currently running.
Power is a tad over 900awhp or 671kw's @ 30 PSI of boost on E85
PB of 8.97sec at 150mph makes it 2nd Fastest Street Tyred Manual Gearbox GTR in the World
-HKS T62R Turbo
-Jun 2.7lt Stroker kit with Custom 86mm CP Pistons. Godzilla Spec Engine.
-Godzilla Motorsport Race Head
-Custom Jun 295 degree x 11.8mm Lift
-Full Tomei Valvetrain.
-Hypertune Plenum with 4" Throttle Body
-ARE 150mm Intercooler
-Trust Exhaust Manifold with 50mm Wastegate
-2000cc Injectors
-Vipec V88
-M & W CDI Ignition with Weapon X CDI Coils
-5 x Bosch 044 fuel pumps
-Peterson 4 stage Dry Sump Setup
-4 Inch Exhaust
-NPC Twin Plate Clutch
-PPG 5 Speed Dogbox with Ignition Cut.
Here's what 8sec with H-Pattern Looks like. :yes:
  • Like 1
When it got weighted at Jambo it tipped scales at 1440kg that's was with half tank fuel and no driver. Car has all factory glass and steel panel except the bonnet. So pretty much weighs same as a stock R32 which is a surprise lol
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Could we bother you for a dyno sheet with RPM on the bottom axis? It would be most appreciated!
It runs a stock standard RB26 bottom end, not N1 block...
Yes, we ran a 10.3 @ 142mph last night - first run out of two, first time it's ever been raced down the quarter with the sequential & over 600hp...
Bogged down at the start too. In full street trim - 20" rims with shitty Hero tyres.
This car weighs around 1700kgs including the driver & massive brakes.
Will post up vids of the run tomorrow :)
How long is it going to last at that power??? Who knows!!! It's been on over 600awhp for nearly 2 years now, stepping it up to 800+ early September this year. Has done Powercruise Bris, Powerplay Syd, SAU airport runs & 2 runs last night. Yes, we have a 3.2 that's almost ready to go in :)
If you want dyno graphs, various vids etc. then check out our Mercury Motorsport Youtube channel ;)
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
