thought there would be a bit more support even though its not a skyline.
its gotta be more interesting surely?
i hope they do well cos im sick of my mates goin on about bloody holdens 24/7
You mean like all the support nissan has given import owners over the last decade....f**kem
http://www.carsales.com.au/news/2012/sports/nissan/nissan-v8-supercar-too-slippery-33389
looks like the drama's could have started already. what are the expected to do? adjust the whole windscreen to make it more upright?
http://www.carsales....-slippery-33389
Change the front of the car so that it resembles a falcodore more so than an Altima?
it seems the Kelly boys might have done the smart thing and picked a 'slippery' car and the aussie cars having a sook as they shaped like bricks. Commodone and falcon should be trying to make the new model cars more sleek
No one is sooking yet
It's always been known that supercars would be doing CFD parity testing.
I believe from people I speak to regularly that the large teams who have fallen away this year will be the front runners come next year. They have put their best engineers forward into the COtF instead of running current cars
Tekno apparently had revised 888 uprights at the 600 and move up the field, still developing an old platform, relying on 888 for their COTF chassis.
888 have concentrated on the title this year, question will be have they sacrificed some COTF development to be at the front in 2012....
No doubt Roland's juggernaut will be at the top of the tree in no time come 2013 but you do wonder if the COTF program suffers at all due to current events.
HRT have sucked arse all year, have they shifted focus from 2012 to 2013.......
Current VE and FG's are far from bricks. They have very strict splitter angles and undertray designs that must be adhered to. No doubt the Kelly cars will be assisted or hindered depending on CFD results.
It was put out there right at the start of the COTF announcement that all new cars / body's will be independently aero tested for parity prior to the 2013 season.
Clipsal Launch at Vic Park next friday from 12 - 1.30pm
Itis not like 888 have any shortage of resources. The joy of having bazillions of dollars in sponsorship is you dont have to chose between development paths. You just do all of them and see which works better.
well given that the commodore gets cut in half and widened by 10cm or so to make it meet current regulations, yeah.
Troubles in the T888 camp
The Red Bull Racing team for next year has one of its drivers in a contract to Monster!!
http://www.speedcafe.com/2012/11/09/monster-energy-set-to-take-jamie-whincup-to-court/
Was at the Clipsal Launch yesterday with the Erebus boys, whose role was rather disappointing with the SLS doing 1/2 a lap of the temporary track where no spectators were only to park.
Ken Block for on track entertainment every day, KISS & Motley Crue in concert on the Friday night
I was surprised to see they let Courtney and Davidson do some laps with each other around the temporary circuit ( at a reasonable speed) in just shorts T Shirt and no Helmet. If anything had happened that would have been a legal nightmare! All stemming from Courtney having to fill in for a sick Tander at the last minute and Courtney refusing to wear someone elses helmet and racing suit, which is understandable but Shit hapens
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
